Rear Cup Holder Stuck - Disassembly advice?
One of my rear cup holders is stuck; it looks like someone pushed it too hard. Does anyone know how to remove that assembly?
Eli
2001 A6 2.7T 6-speed
Eli
cupholders. With a screwdriver you can pry off the outer plastic trim piece surrounding the cup holder. With this off, you can then access the slots over each cup holder, maybe 1/2" wide, where you press with a screwdriver to release the tabs that hold the cupholders in.
Good Luck!
Good Luck!
AudiWorld Expert
<ul><li><a href="https://forums.audiworld.com/a6/msgs/209643.phtml">rear cupholder removal</a></li></ul>
sortadan
08-27-2004 04:12 PM
