rebuild transmission due to no reverse,after 4 days i have no gears at all
hi everybody,
I just finish to rebuild my 5hp19 fla transmission and installed back in my 2003 allroad 2.7t.
it ran great for few days,yesterday I loose all gears forward and reverse ,after I was stop at an intersection.
at the begin it was show me the gears on the display (including the 1 to 5)
and after a little bit the display show me the prnds is solid all red and the vehicle moves like neutral, park working and I have no mil or dtc's from my code reader.fortunally my road is going down hill end I was able to back it up back home in neutral.
the connection at the transmission are solid and no leaks.
what it can be?what to look at it?
bad TC , module ,transmission leaks internally?
I check the fault codes for the transmission.
I have p0711 (17095) transmission fluid temperature sensor circuit g93 range / performance,
p0730 (17114) gear incorrect ratio and p0811 (17195) excessive clutch slippage.
anyone have idea of what going on?
I will check the fluid level (it may be low?)
am I need to remove the oil pan for inspect the solenoid pack harness and solenoids?
where is locate the transmission fluid temperature sensor?
thanks
thanks
I clear the codes and the p0711 is not coming back,but I have the other 2 coming back after I try to shift with the car not moving at all.
I suspect the valve body is bad but I'm not an expert on transmissions.
for example, Google: "ross tech P0711"
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
Jorge Vargas
09-08-2015 07:45 AM
ajg617
09-06-2015 07:23 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
