Recoding service interval indicator... ?
Searched both the forum and Stoney's links but couldn't find a reference.
Is it possible to recode the service inveral indicator to come on at 5k instead of 10K? I'm inclined to change my oil a bit more requently than 10k...
Thanks in adavance.
Thanks in adavance.
I'll look this weekend if you don't have the manual. I think it's pretty straight forward with a VAG-Com.
Resetting SRI without using VAG 1551 or 1552 Scan Tool (ST)
- Switch ignition off.
- Press and hold down reset button for trip odometer in instrument cluster.
- Switch ignition on while button is pressed down. "Service OIL" appears in the display of the trip odometer.
- Release button.
- Pull setting **** for time in instrument cluster until "Service OIL" indication is reset.
"- - -" appears in display.
- Press reset button for trip odometer again, to advance to next service event.
- Release button. "Service INSP" appears in display.
- Pull setting **** for time -1- until "Service INSP" indication is reset. "- - -" appears in display.
- Release button.
...the interval of the reminder.
Specifically, it's now set to remind me every 10k miles. I want it to remind me every 5k.
Thx.
Thx.
- Adapt Service Reminder Indicator (SRI) as follows:
The interval values (distance) must be adjusted (adapted) to the applicable intervals of 12,000 km (7,500 mi) or 24,000 km (15,000 mi).
The adjustment is carried out in adaptation channels 5 and 6.
Notes:
The adaptation must be made in kilometers, even in countries where speedometers record distance in miles. To do this, convert the adaptation value from miles to kilometers. Conversion of miles to kilometers: miles x 1.609 = km.
Kilometers are displayed in "Read Measuring Value Block" function 08, display groups 002 and 050.
The specified values can only be input in increments of 1,000 km. Therefore, the display would indicate 1,000 km by a "1" in the display.
If an incorrect value is input, "Adaptation" function 10 is ended and must be initiated again.
- Connect VAG
VAG - ON BOARD DIAGNOSTIC HELP
1 - Rapid data transfer 1)
2 - Blink code output 1)
Indicated on display
1) Operating modes 1 and 2 appear alternately
- Press button -1- to select "Rapid data transfer" operating mode 1.
Rapid data transfer HELP
Insert address word XX
- Press buttons -1- and -7- to insert "Instrument Cluster" address word 17 and press -Q- button to confirm input.
4B0919930B C5-KOMBIINSTR UN4 D13
Coding 07062 WSC 12345
Indicated on display (example)
- Press button.
Adapting Service Reminder Indicator (SRI) channel 5, oil change service interval value (distance in km)
Select function XX
- Press buttons -1- and -0- to select "Adaptation" function 10 and press -Q- button to confirm input.
Adaptation
Insert channel number XX
- Press buttons -0- and -5- to insert channel number 5 (05) and press -Q- button to confirm input.
Channel 5 Adaptation 15
<-1 3->
The interval value for the oil service is displayed (e.g. "15" corresponds to 15,000 km, or 9,375 mi).
- Input interval value in units of 1,000 km, filling first digits with zeros ("000").
Example: Interval value: 12,000 km (7,500 mi)
Value to be input: 00012
Channel 5 Adaptation 15 Q
Input adaptation value 00012
- Press -Q- button to confirm input.
Channel 5 Adaptation 12 Q
<-1 3->
Store changed value?
Changed value is stored
- Press button to end adaptation of SRI channel 5.
Select function XX
Adapting Service Reminder Indicator (SRI) channel 6, inspection service interval value (distance in km)
Select function XX
Adaptation
- Press buttons -0- and -6- to insert channel number 6 (06) and press -Q- button to confirm input.
Channel 6 Adaptation 30
<-1 3->
The interval value for the inspection service is displayed (e.g. "30" corresponds to 30,000 km, or 18,750 mi).
Example: Interval value: 24,000 km (15,000 mi)
Value to be input: 00024
Channel 6 Adaptation 30 Q
Input adaptation value 00024
Channel 6 Adaptation 24 Q
<-1 3->
- Press button to end adaptation of SRI channel 6.
Select function XX
Notes:
- Connect VAG
- Press button.
Select function XX
Adaptation
<-1 3->
<-1 3->
Select function XX
Select function XX
Adaptation
<-1 3->
<-1 3->
Select function XX
a4shon
Southeast Discussion
05-29-2006 03:15 PM
BARONVON5
03-18-2004 06:20 PM
letS4nicate
Audi allroad
12-31-2002 08:11 AM
nasty nate
06-04-2002 09:20 PM
