Remote access key programming
Hi all,
I purcahed 2002 A6 C5 2.7T with one key and broken door lock which I cannot insert the key into.
I managed to find another used key from other car and in addition I purchase new key from eBay in order to program them.
I managed to program the used key to open and closed the car using VCDS and the original key stoped working and I could not program the new key at all.
I tried several times with VCDS and always ended up with only the used key from the other car to work.
Any ideas ?
Thanks
Yaron
Yaron
Any ideas ?
Thanks
Yaron
Yaron
I reset chanel 00 and retry programming all 3 keys, and I sill was able to program only 1 key and the same one as before.
Is there a way that the new key I purchased from eBay works on other frequency than my car cluster ?
If yes how can I tell ?
Tx
Tx
Of course, there is another possibility...
You may be able to get some of your money back by reselling the wrong transmitter on Ebay or a similar site. Keep us posted about how things go. This is a good tutorial for others.
