replacing front rotors (HP2 brakes). do i remove 2x 21mm bolts or the 7mm ones?
searching the archives. the A4 tech article shows removing the plastic caps to access the 7mm bolts to remove the caliper. something tells me that's not right for the A6/ar. (now that I look again, the bolts under the plastic caps don't have a hex, int or ext, on them) However, i can't get those 21mm bolts to budge. I only want to get the rotors off, not replace the caliper. help, please.
messy job, by the way, geez
I had to turn the steering all the way to the end to get leverage from the side of the car...
trying to do it from under the car will probably not fly... The bolts are fine thread and they ahve some anti-loosening pattern on the contact face of the head. You will need a decent size breaker bar.
AudiOx
Audi allroad
16
05-19-2008 06:17 AM
Shiny Red Beast
21
01-23-2006 04:17 PM
Sacer
9
10-10-2003 04:27 AM
