Replacing just the ABS Sensing Ring on the outer CV Joint--possible?
Somehow, I bent mine out of shape during the driver's outer CV Boot replacement and I now have ABS/ESP lights.
I'd like to avoid buying a new CV Joint if I can. Anyone w/ experience on this one? Couldn't find anything of substance STFA.
when replacing the CV boot, it's probably OK. You need to reseat the sensor against it. Do so with a piece of paper between the two, to establish a minimal clearance.The sensor is a push fit into a spring sleeve.
does anyone have a picture of the abs sensor? i have the same problem my ABS and Brake light keeps flashing on my dash and beeps 3 times
<center><img src="http://pictureposter.audiworld.com/88200/img_2320.jpg"></center><p>...pull the sensor and look down in the hole. You'll see the hashmark-like surface of the outer CV Joint, which may be gunked up and preventing the sensor from sensing. Spray it w/ brake cleaner as you turn the hub to clean all the way round.
If the sensor is stuck, wiggle it back/forth--it shouldn't be too tough to free it.
This pic is from the front of the car, looking back at the driver's CV Boot. The ABS Sensor is right in the middle, sensor wire leading into and up the upright.
I just found an outer CV joint kit at Blauparts for $99 (joint + the normal boot kit). I think I'm just going to get that (which I probably should have done when I "fixed" the boot the first time!)
and must then be driven out from the inside, destroying the sensor, BTDT.
Eightmn
11-08-2014 08:47 AM
luvluvS4
09-21-2005 11:29 PM
halik
05-20-2005 07:18 AM
