replacing pass glass laminate or tempered?
Called a few different dealerships asking if I can use tempered glass and none knew if I could or not. They of course recommended the 4x more expensive laminate piece,but still can sell me the tempered piece. They didn't know if the seals/motor was the same for the tempered glass can anyone help me out here?
thanks!
thanks!
The way my glass broke points to it being a laminate(large cracks with no spiderwebing). There was also a break in the '98 vin#'s so this could be true in the latter half of the year.
I've talked to two Audi dealers and both recommend the laminate glass,but after searching around here I see there's two adjustment functions that can be performed to firm/loosen the glass in the window frame.
Anyone have any experience with this?
If the window was tinted, the tint will hold the shards together making it seem as if it's laminated when chances are it's just tempered. The shards of tempered glass are also quite tiny compared to the large shards that laminated glass produces.
The most telling feature of laminated glass is, however, that it holds its shape quite well when broken because of the thin plastic sheet that exists between the two outer thin glass sheets.
That said, when you roll down the other side windows and examine the edge of the glass, is it ground with a smooth rounded edge (in which case it's likely tempered) or is it flat with what looks like a striped channel running down the middle of the edge of the glass where the plastic laminate is sandwiched between two thin sheets of glass (in which case it's likely laminated)?
Coming from an '02 Volvo S80 T6 which was factory equipped with the laminated side window glass option, I did find it odd that the '02 A6 4.2 has regular tempered glass side windows.
I spoke to another dealer and he had said the tempered glass is thicker and my car might not accomodate this. However searches here indicate there are two adjustment areas in the door to firm/loosen up the fit. The various dealers didn't want to really investigate this (not a surprise).
I may just try the tempered piece at a quarter of the price. One shop said they can install it and if it doesn't work they will order the laminate and I won't have to pay. It would be good to hear from someone who has dealt with this problem though.
Hmmm, another thing to check when buying a used C5...whether some cheap PO put in tempered glass. Ought to reduce the price of the car by a thousand or so.
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
Audi A8 2005 Audi A8L
Jan_PL_S6
12
11-27-2015 07:27 AM
Touge.ca
Canadian Discussion
09-02-2015 01:30 AM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
