Replacing PS return lines?
A while back, I flushed the PS system...removed the return line between the cooler and the reservoir, reinstalled with a hose clamp, and all was well until the first cold snap (or maybe it just took that long), when I began to hear the pump cavitating and added fluid (bad sign...adding fluid means there's a leak). Didn't have an opportunity to look at it until yesterday, when it started making noise again (incidentally, another cold snap), and I found pinhole leaks at the cooler end of the return line from the rack, and a leak in the vicinity of the new hose clamp on the cooler side of the return line to the reservoir.
I did not mess with the return line from the rack, only the line to the reservoir. Are these lines (low pressure, remember) simply getting old? It's an 04, I certainly don't have a problem replacing 7-year old hoses, but I'm concerned I did something to damage the lines.
I flushed with the Audi Pentosin...the green stuff. What came out was red, and filthy...it had not been changed previously, with 100K miles on the car.
Dealer wants well over 100$ per hose, which is simply stupid. These are low-pressure return lines...can I have something made local from Aeroquip or the like?
Is this what I'm after?
http://www.autopartswarehouse.com/se...+Steering+Hose
Because if that's the case, I'm going to use the appropriate US-made low-pressure fuel/oil line available at the local ranch supply for a buck a foot. The larger of the leaks seems to be on the easy-to-replace line from the reservoir to the cooler. Is there a fitting on the line from the rack (it uses a banjo bolt) to the cooler, and is it a standard fitting?
Thanks all!
-Sean
Thanks all!
-Sean
My experiences
Mine is a 2000 4.2 and now 12 years old at 127K miles. Owned since new. I have done the full flush by opening the low pressure lines at clamp points and drawing in new fluid from the reservoir return hose. My experience is the lines do tend to deteriorate, but only at the ends (likely air or fluid interaction). They are also prone to receding under the clamp some. Fixes simple--just trim off line ends a tiny bit, and check clamps some months after I have opened anything; they typically have needed a second snug up after I have opened it for some reason.
Further inspection revealed the return line between the rack and the cooler is completely rotten, several inches above the clamp and normally hidden from view by the flex tube wrapper. The return line to the reservoir, and the area under the pipe clamp I installed, actually seems to be in decent shape.
The Bentley manual I have (the maintenance-oriented version) is completely worthless as far as accessing the steering rack, and the banjo fitting at the other end of the damaged hose. Does the Bentley service manual include the necessary procedure? Accessing that fitting doesn't require something asinine like pulling the engine, does it?
TIA,
Sean
TIA,
Sean
Found some articles, for an A8, A4 and my 2.7T A6...
http://www.audipages.com/Tech_Articl...eer/srack.html
https://www.audiworld.com/tech/misc-40.shtml
http://www.justanswer.com/audi/4p1zh...ring-rack.html
https://www.audiworld.com/forums/sho....php?t=2803825
All I need is to get at one banjo bolt, not remove the entire rack. I'm going to take a look tonight, but any tips or suggestions in advance would be much appreciated.
TIA,
Sean
TIA,
Sean
aeroquip? Not SS but kevlar braided. The blue colored stuff.
Yeah, that's the stuff...it's pretty bomber. Bilstein uses it on their remote reservoir shocks...very durable, much more so than the dubious stuff Audi used for these hoses.
Unless you have a better suggestion? I was thinking Aeroquip because it's multi-layer, and the outer layer is pretty durable...that hose is fairly exposed to grime and my car didn't come with a belly pan. I'm not even sure if it had one from the factory.
Oh yeh...it had one from the factory. Previous owner probably ditched it...they're kind of spend to replace and they're plastic. I'm surprised no one has fabbed up an aluminum plate one...every car I've ever owned that it was possible to replace the belly pan with aluminum I did so (volvo..).
Andy_FL
09-25-2016 11:58 AM
Asicks2.7T
13
05-22-2008 07:52 AM
BeeRock::Riding Red
02-22-2008 06:10 AM
sk88erguy
Audi Original "S" Cars
02-19-2006 11:17 PM
