Rotor rubs on caliper, any ideas?
#13
I used this Bendix site for reference and found that the 2002 models seem to have a difference in the 321mm rotors vs 2001
http://www.bendixcatalog.com/PartDet...=Brake%20Rotor
#14
#15
According to the tag on my Audi service record manual, my code is 1LX which is what the rotors I bought are made for. The two rotors you show are the (approximately) 16.7mm offset and the 22.7mm offset. Supposedly the 22.7mm offset is only for the A6 with the 4.2L. But like I said, the Audi parts department said a 320x30mm rotor is called out for my car. He gave me a print-out with the part number that I mentioned before, I have this at home and I will scan it when I get back. Either way, that rotor from Audi is identical to the rotor from blauparts and to the rotor I took off my car (except for the turned down thickness) and neither of the new rotors fit without rubbing on the caliper. It seems the rotor dimensions are correct so something else must be different. I did change the cv shafts a year and a half ago or so but I am not sure how that would affect this situation although its in the same area. I installed the blauparts rotors with 2 mm thick washers in between where the caliper mounts to the upright and it centered the rotor perfectly and so far there are no issues but it should not have to be this way...
#16
#17
Even the rotor straight from Audi rubs in the same spot. The caliper assembly has no effect because where its rubbing is a solid chunk of metal. Once it is bolted, it does not move and there is virtually no play in how it bolts to the upright. It is not rubbing on the floating part at all. Also, in all the research I have done for this I do not recall coming across a 312mm rotor for the dual piston lucas calipers.
#18
do you have the old rotor? is this front or rear?
if it is rear, measure the hat height on the old rotor and get back to me, i literally have a spare rear rotor set in my garage that were the wrong hat height someone just gave to me!
#19
Yes I have the old rotors. I am talking about the front. I don't need rotors. I would like to understand why the correct rotors for my car do not fit.
#20
take my car, my front axles have a standard cv join on the inside, same as the outside. according to audi, they shouldn't exist on my car in the USA, but a select number during the split year (2002) were built with EU spec parts due to not having the USA spec parts from the manufacturer soon enough.
fast forward, now when i look i cant find parts for that axle, and im pretty much SOL when the inner goes as while the cv joint can be replaced with a standard part, the retaining clips are not being sold in the USA anymore and i cant source them from germany.
long story short, sometimes audi does crap behinds the scenes and it pisses everyone off, my advice would ne to get ETKA ASAP. its the only thing that keeps me somewhat sane
