Rough Idle First 30 Seconds Cold Engine
Old 09-16-2005, 05:50 AM
  #11
Edd W's Avatar
Right on top of the engine at the front under the plastic cover.
Old 09-16-2005, 01:49 PM
  #12
kccmc's Avatar
Default Re: Rough Idle First 30 Seconds Cold Engine
I should add that the trouble codes are 16684 (P0300) Misfire Recognized, and 16686 (P0302) Misfire Detected Cylinder 2, both recorded as intermittent.
Since each coil drives two cylinders, I'd be surprised if it was a coil.
Old 09-21-2005, 12:06 PM
  #13
kccmc's Avatar
Default Re: You have a bad MAF.
The MAF-induced problem would only last the first 10-25 seconds after cold start? Seems like a bad MAF would cause broader problems. Were your symptoms as specific and limited as mine?
Old 10-04-2005, 05:09 PM
  #14
New Member
mi6ke's Avatar
My 2002 A6 does the rough idle in the a.m., but sometimes as long as 10 minutes. Doesn't do it every day. Error messages showed three cylinders misfiring but that can't be true because it runs perfect after the first few minutes. Anybody consider it's the computer?? Anybody come up with a solution that works?
Chuck-S4
03-05-2021 10:09 AM
ajg617
07-22-2014 04:45 PM
dr13
1.8T Discussion
05-13-2012 05:42 AM
BiturboBoy_V2.0_S3--
03-29-2001 12:53 PM
Quick Reply: Rough Idle First 30 Seconds Cold Engine
