RS 6 F&R Bumper, Side Skirt, Bi-Xenon, Wheel, Exhaust & Carbon Trim Part #'s + ETKA
AudiWorld Uber User
This list below was created 3/05 and is no longer updated. The dealer list price for many of these items has probably increased due to the limited production of the RS 6. This list does not include paint or labor. (Always confirm with your dealer before ordering).
<img src="http://pictureposter.audiworld.com/33185/front.jpg">
<b>RS 6 Front Bumper Assembly</b>
Front Bumper Cover: 4B3-807-105-B-GRU Bumper $849.70
4B3-807-109-F Beam $295.33
Upper Grille (No RS 6 Badge): 4B3-853-651-G-1L1 Grill $191.54
Hood Latch: 4B3-823-480-F Hook $97.65
Lower Grill: 4B3-807-490-F-1L1 Grill $183.52
Fog Light Assembly 8D0-941-699-E Fog Lamp $153.03
Fog Light Assembly 8D0-941-700-E Fog Lamp $153.03
Fog Light Bracket 4B3-807-593 Bracket $74.48
Fog Light Bracket 4B3-807-594 Bracket $74.48
Fog Light Grill: 4B3-807-681-D-3FZ Grill $83.45
Fog Light Grill: 4B3-807-682-D-3FZ Grill $83.45
4B3-807-173-E-1L1 Trim $64.13
4B3-807-174-E-1L1 Trim $64.13
4B3-807-489--3FZ Trim $33.77
4B3-807-490--3FZ Trim $33.77
4B3-955-259--GRU Cap $14.42
4B3-955-260--GRU Cap $14.42
3B7-955-681 Pump $32.25
8D0-955-101 Cylinder $103.88
4B3-807-271-B Bracket $155.20
4B3-807-272-B Bracket $167.82
4B3-807-721 Bracket $24.08
4B3-807-722 Bracket $24.08
4B3-807-787 Frame $16.12
4B3-807-788 Frame $16.12
4B3-807-867 Plate $19.72
4B3-807-868 Plate $19.72
N-900-590-01 Pop-Rivet (Ordered 6) $0.67/ea.
N-900-349-01 Pop-Rivet (Ordered 4) $0.37/ea.
4B0-807-190-B Screw (Ordered 2) $2.32/ea.
4B0-807-199-F Screw (Ordered 4) $2.62/ea.
4B0-807-895-A Bolt (ordered 6) $3.18/ea.
4B0-807-199-G Bolt (Ordered 2) 0.33/ea.
4B0-807-467-B Grommet (Ordered 6) $0.52/ea.
N-001-664-10 Washer (Ordered 4) $0.33/ea.
4B3-807-739 Mount Kit $5.70
<a href="http://allroadfaq.com/rs6/RS6bumper.pdf" target="_blank">ETKA - RS 6 Front Bumper.pdf</a>
<b>RS 6 Side Skirt Assembly</b>
Side Skirts: 4B3-853-859-C-7DL Trim $476.67
Side Skirts: 4B3-853-860-C-7DL Trim $476.67
4B3-853-959-A-7DL Cover $83.30
4B3-853-960-A-7DL Cover $83.30
4B3-853-969-A-7DL Cover $58.28
4B3-853-970-A-7DL Cover $58.28
(I returned these parts), as I was able to use the existing mounting brackets from the 4.2 but they are:
Side Skirt Bracket: 4B3-853-921 Holder $8.97
Side Skirt Bracket: 4B3-853-922 Holder $8.97
(I returned these parts), but if anyone wants the part numbers to the inside door trim with the RS 6 logo's on it, they are:
4B3-853-491-B-01C Scuff Plate $173.40
4B3-853-492-B-01C Scuff Plate $173.40
4B0-853-905-A-7PE Scuff Plate $72.40
4B0-853-906-A-7PE Scuff Plate $72.40
<a href="http://allroadfaq.com/rs6/RS6sideskirts.pdf" target="_blank">ETKA - RS 6 Side Skirts.pdf</a>
(I returned these parts), but the protective trim that runs along the center of the door are:
4B0-853-953-B-GRU Strip $38.42
4B0-853-954-B-GRU Strip $38.42
4B0-853-963-B-GRU Strip $33.20
4B0-853-964-B-GRU Strip $33.20
<b>RS 6 Bi-Xenon Headlamp Assembly</b>
(I returned these parts), but the part # to the RS 6 Bi-Xenon Headlight assemblies are:
4B3-941-003-K Headlamp $570.28
4B3-941-004-K Headlamp $570.28
I have also secured the remaining rear bumper information, although I have yet to modify the rear bumper, or add a spoiler for my 4.2 (with the exception of the RS 6 exhaust fitment, listed below). The parts list and ETKA for the rear bumper are as follows;
<b>RS 6 Rear Bumper & Spoiler Assembly</b>
Spoiler: 4B5-827-933-GRU - $450.00
Bumper: 4B4 807 303 H GRU - $969.08
Sealing washer: (4, four) - 4B0 807 405 A
Side Reinforcement: 4B0 807 313 F - $137.37
Retainer - left: 4B0 807 331 E - $55.68
Retainer - right: 4B0 807 332 E - $55.68
Retainer - left lower: 4B0 807 329 - $7.57
Retainer - right lower: 4B0 807 330 - $7.57
Adapter: 4B3 807 083 - $1.98
Snap nut: (2, two) - N 015 437 3 - $2.66
Oval head panel screw: N 908 311 01 N - $0.30
Torx socket head panel screw: (2, two) - N 907 750 01
Guide piece - left: 4B4 807 453
Guide piece - right: 4B4 807 454
Expanding nut: (6, six) - 443 807 300 A
Oval head panel screw: (6, six) - N 900 626 03
Hexagon nut, shouldered: (4, four) - N 901 752 03
Hexagon nut with washer: (6, six) - 4B0 807 457 A - $0.64
Grommet: (6, six) - 4B0 807 467 A
Attachment bolt: (6, six) - 4B0 807 893 A
Washer: (2, two) - N 011 558 11
Hex.hd. thread cutting bolt: (4, four) - N 906 478 01
Hexagon head bolt: (combi) (4, four) - N 907 721 01
Hexagonal bolt (4, four) - N 010 238 20 - $0.42
Hexagon head bolt: (combi) (2, two) - N 907 071 01
Washer (4, four) - N 908 172 01 - $0.49
Sealing - left: 4B0 807 185 A - $3.05
Sealing - right: 4B0 807 186 A - $3.05
Ultrasonic sensor (4, four)
Sound absorb. for side member: (2, two) - 1H9 864 733
Bumper covering - left: 4B6 807 833 3FZ - $49.34
Bumper covering - right: 4B6 807 834 3FZ - $49.34
Trim: 4B6 807 819 3FZ - $53.16
Cover for bumper: - left 4B9 807 795 3FZ - $50.07
Cover for bumper: - right - 4B9 807 796 3FZ - $50.07
Torx socket head panel screw: (4, four) - N 907 750 01
<a href="http://allroadfaq.com/rs6/RS6rear.pdf" target="_blank">ETKA - RS 6 Rear Bumper.pdf</a>
The following list below is for the RS 6 Sport "Enhanced Sound" Exhaust, which is a 3 piece exhaust system featuring anodized charcoal gray color rear mufflers and exhaust tips. It differs from the standard RS 6 exhaust, which is a one piece construction and features chrome exhaust tips.
<b>RS 6 Enhanced Sound Sport Exhaust Assembly</b>
Middle exhaust [4B6 253 121]: $451
Exhaust Silencer (Muffler), Rear tail pipe (black)
-Left [4B4 253 607]: $641
-Right [4B4 253 612]: $641
Cross support [4B3 253 521B]: $53
Dual Clamp (need 4) [8L9 253 139 A]: $50 (each)
This list is for the 18x8.5 ET30 RS 6 9 Spoke Wheel, which requires specific center caps, sold separately.
<b>RS 6 Nine Spoke Wheel & Center Cap</b>
Type: RS6 18" standard wheel (Spec: 8.5J x 18, ET30, 5x112) - 4B3 601 025 R 1H7 - $749.95 (each)
RS 6 Center Cap - 4B0 601 147C Z17 - (4 needed) - $49.99 (each)
I have converted my interior wood trim to that of the RS 6 Carbon Fiber interior trim. The part numbers are as follows:
<b>RS 6 Carbon Fiber Interior Trim</b>
4B1-853-190-AJ-1J2 - Dash trim above glovebox - $333.00
4B0-857-967-AK-1J2 - Ashtray cover - $137.00
4B0-864-261-FJ-1J2 - Shift surround - $361.00
4B0-863-321-T-1J2 - Hazard/cupholder/ESP switch surround - $190.00
4B0-711-463-AJ-1J2 - Brake lever - $236.00
4B0-862-383-P-1J2 - Storage tray under armrest - $273.00
4B0-863-209-Q-1J2 - Trim between brake lever and storage tray - $123.00
4B0-863-210-AD-1J2 - Trim under armrest hinge - $186.00
4B0-867-409-P-1J2 - Front door insert left - $271.00
4B0-867-410-P-1J2 - Front door insert right - $271.00
4B0-867-419-P-1J2 - Rear door insert left - $238.00
4B0-867-420-P-1J2 - Rear door insert right - $238.00
Special thanks to AudiWorld member <b>Boston Driver</b> who is responsible for the creation of half of this parts list and thanks to member "uber_ar" who's server space makes the downloads possible.
<img src="http://pictureposter.audiworld.com/33185/old_car.jpg">
I think I saw them for $2.61 each at Harbor Tools. : )
WOW MAN. That's a list. Makes me want to buy a 4.2 jsut to take advantage of the work you put into it!
CAN'T WAIT TO SEE THE FINISHED PRODUCT!!!!
On second thought, you could probably part out an entire RS6 and make enough back to just buy one outright for your $2500 out of pocket costs!
hahahahaha
hahahahaha
It's why I never subscribe to the belief that some aftermarket tuner can match a factory effort (if the factory bothers of course;-).
