SAP Part #'s
My SAP is going out on my '99 A6 quattro. I think I've found an OEM pump at a salvage yard. My question is should I replace the hoses going to the SAP? I found these part #'s somewhere: VOLKSWAGEN 078-133-817-P PIPE
VOLKSWAGEN 078-133-889-H PIPE. My VIN is WAUBA34BOXN133984.
Are these part numbers correct for my car (had a friend tell me it depended on my VIN)? Do you think I should replace anything else while I've got her apart?
THANKS AUDIWORLD!!!
THANKS AUDIWORLD!!!
I wouldn't replace em .. just the pump
when i checked my pump the hoses were just fine ..
BTW did you get the graphic i sent ?
Just got back in town tonight
If you hear very loud noises on cold startup while the pump is running, then most likely the SAP shaft bearings are going bad. This condition is usually the result of moisture being blown into the outlet hose by a failed diverter valve. Over time, the mositure corrodes the bearings, then it will seize.
Li3ny
11-20-2008 06:58 AM
Fast Euro
07-23-2008 07:56 PM
.357
09-05-2006 09:29 AM
Steven Lin
03-18-2003 09:09 AM
