Seized 3.0 Engine Advice Needed
2004 3.0 w/ 57K. Had oil changed by local mechanic. I did not check oil immediately and car sat for 3 months while we drove TT. Started it up last week (very cold - 8F) and MIN OIL light came on. I was dumbfounded but added a quart. Light came on again and I added another 2 quarts. Drove back home (about 100 miles total) Turns out "mechanic" only added 4 quarts (7.3 capacity).
Next day engine wouldn't turn over. I can see volt drop from 12+ to 12- and can hear starter engage but there's no turning of engine or starter. Easiest check was battery which I replaced with new Interstate bat but still same results.
Any advice appreciated and I'm sure I'll get some deserved barbs.
Can you turn the engine over by hand? I don't see the low oil thing being that much of an issue. Is it cold where you are? Is the bank one cam seized due to oil starvation (which has happen to a few 3.0's but would not be related to simple low oil)?
After putting transmission in neutral I cannot turn engine by hand - do you just grab and pull on the barely accessible belt on port side?
But after trying by hand I tried starting again and it started right up. (It's warmed up to 32F.) So now what? We really like our car and want to keep it for a long time. Should I have the car looked at by a qualified Audi mechanic? What would we be looking for? There is a slight clicking noise like valves which I don't remember hearing before.
Thanks for the advice. One of the reasons we bought an Audi was the great user support in this forum - I hope Audi realizes this.
to turn over....
1. remove spark plugs ( opptional, but makes it easier to understand what is resisting you)
2. put a breaker bar and socket ont eh crank and turn
should spin like a top
Let's not blow this out of proportion. The car has been sitting for three months; of course the lifters are going to be a bit noisy until the car is run at temp for a while. 4 quarts is plenty for safe operation. Send the oil out if it makes you feel better, but don't lose any sleep over this.
Check the starter circuit if the problem comes back.
Thanks to all of you. Feels good to have support from knowledgeable people.
For now it's working. I went to a local mechanic for a listen who said it sounds good. Maybe it was a coincidence and unrelated to the low oil. If anything else turns up later I'll report back but now we're celebrating that our car is back with the living (and we're not out thousands of dollars)!
I would argue that while 4 quarts of oil is not full of oil, it is certainly enough for the engine to be fully oiled. All you really need is enough oil to feed the pump for basic lubrication. Anything over that just helps to keep the oil cooler.
carl viking
40
07-12-2024 02:45 PM
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
