Last edit by: IB Advertising
- Audi A6 C5 Why is There Frong End Rotation Grinding Noise<br>Guide to diagnose trouble and recommended solutions.
Slightly Grinding Front End After Reverse
First off:
2002 3.0L Quattro
112,000 Miles
After backing out of a spot or driveway I hear a slight grinding coming from what sounds like the driver side front wheel. I do not notice this if I come to a stop then go again. It only last for about a 1/4 of a tire turn. Before I head off to the dealership, any ideas? Thanks.
B
2002 3.0L Quattro
112,000 Miles
B
AudiWorld Expert
Check the dust shield which is on the inside of the brake rotor. Just push it away from the rotor in a few spots and see if that helps. Warning...your hands will get dusty from the brake dust, si if you care about your shirt cuffs, roll up your sleeves!
AudiWorld Expert
Ride is doing well. Picked up a silver 2002 4.2 in January 2006, since then, I've done a few things to it
)) It just passed 100k recently, and everything is still running smoothly. BTW, I sent you a PM.
Most recent picture I've taken was last fall...
![](http://img.photobucket.com/albums/v739/hliu55/AW%20sig%20pics/August2009.jpg)
I have to go with BD on the dust shield. Had the exact same problem - also driver front. Happened most of the time at low noticable speeds and for a few seconds at a time. Pushed the dust shield back and noise went away
Check that first!
Just found a totally ravaged Outer PS CV - boot after hearing the tell-tale rattling of the deteriorating joint ...... ice and snow did a number on it.
Mine just ticked over 100000K miles too ...... seems like about the average longevitiy of this thin rubber.
Shoulda stayed in Vegas and took the extended layoff !!!
blaqswan
07-05-2013 07:05 PM
