So,,, anyone have an oil filter housing/bracket they don't need?
2001 A6 4.2
Ive had a cracked oil cooler pipe for several months now. Got the Bufkin cure-all and set to it today.
I certainly had a lot of trouble but finally got all 5 of those lame 8mm allens out. While gently trying to work the unit out of the engine bay, I noticed a couple random pieces of aluminum shrapnel drop down. Got worried and worked the unit the rest of the way out.
Low and behold, there is a giant hole and crack in the oil filter housing.
There was an alignment pin in the top-left bolt hole that I believe must have been quite stuck. I tried to be as gently as possible and never felt like I was being very foceful, but apparently I was too much for the fragile eggshell of cast-aluminum.
Anyways, I'd love to post a picture for fun but I dont have a camera. I was really hoping to get lucky and maybe one of you fellas would have a spare (fingers crossed).
Part# 077 115 405 J, or it looks like 077 115 405 M is the latest replacement
Its pretty difficult to locate the part anywhere new. I saw ECS tuning has one for over $700. Thought I'd check here first to see if I could get lucky. I'll call some auto dismantlers on Monday I suppose.
PM or email @ cgranger5k@gmail.com
Thanks guys.
Thanks guys.
Oil Cooler / Alternator Bracket / Adapter Needed (Part #077 115 405 M)
I'm resurrecting this thread as I have the same issue (on my 2002 S6 Avant).
When trying to remove the broken oil cooler pipe (part #077-115-441), my shop damaged (cracked?) the adapter (077 115 405 J). I have searched high and low for a replacement and according to several distributors/dealers I called it is no longer available.
Does anyone know where I can get a replacement (either 077 115 405 J or the updated version, 077 115 405 M)? Or has anyone tried to repair one?
Any pearls of wisdom would be greatly appreciated! (I'm in Chicago).
Many thanks.
Many thanks.
2001 A6 4.2
Thanks guys.
Thanks guys.
2000s4biturbo::Uli
03-25-2005 05:25 AM
Limey
Audi 100 / A6 (C4 Platform)
02-06-2004 05:42 AM
