Some question about H-sport Sway bar.....
my car is 1999 A6 Avant quattro.....i am think about replace my oringinal sway bar to H-sport sawy bar....but i just can't find the right item for my car.....doese anyone know which one should i choose?? for any other brand have my car's sway bar?
Paul
Paul
AudiWorld Expert
Good for the A6 Quattro and S6, which means good for Avant too, right?
<ul><li><a href="http://www.h-sport.com/cgi-bin/EDCstore.pl?user_action=detail&catalogno=22822 ">H-Sport Sway</a></li></ul>
Only difference is the shape of the rear bar.....
Front bars are both the same. allroad rear bar has a different bend in it to clear the air suspension compressor. But either will work on the A6 Avant. Just can't use the A6 bar on an allroad. Makes an even bigger difference on an Avant because of all the glass back there. Go directly to the hard setting on the rear bar for an Avant. And smile at every turn.
The other issue is that in 1999 sometime the front links were re-designed.
The H-sport sways are designed for the new links (with a through bolt, not a captive stud in the link.)
Have a look at the top of your front links and see if theres a hex head on both sides of the sway bar / link rod connection, if not you'll have to change the 2 links. Not too expensive though.
Or do this....
I did this several months back and it's been a great improvement. If a '99 needs different drop links, this is a great alternative to the factory style, and probably les $$ too<ul><li><a href="https://www.audiworld.com/tech/wheel42.shtml">Drop link tech article</a></li></ul>
Re: Or do this....
oh.....i have ever check my sway bar link before.....and i notice that my sway bar link just look like what are you show me on the "Drop link tech article"....I mean the original one...that means i don't need to change them???
