Starting issues
Hi no engine check light on and I have had the AA mechanic out and he has run a scan on it and he tells me there is a fault between the fuel pump fuse and the fuel pump itself.When the car won’t start he is only getting 0.9 volts should read 12volts.The car is stranded at work I am able to start it every day but it only runs until it is up to working temp then it shuts down, I can only crank it over after that no fuel up at the fuel rail and no pump going.
I would guess that the Fuel Pump Relay has a burned contact which is limiting the amount of voltage and amperage to your fuel pump.
You may be able to bypass the relay with a jumper, but only if you are an accomplished mechanic who likes taking risks. If it were me, I would have it towed to a shop that can do a proper diagnosis.
El Desamparado
Audi Original "S" Cars
11-30-2006 01:56 PM
AcesFull
10-10-2004 04:32 PM
Longwolf (Christian)
04-19-2002 07:44 PM
