starting problem - crank times getting longer
Car is 01 2.7 A6 with manual trans. 150k miles.
2 days ago the car cranked for a few seconds and then started. By today, the cranking has lengthened to about 5-7 seconds. If I try an immediate restart, no problem. If I wait 10 minutes to overnight, the crank time extends to 5-7 seconds. Car runs fine once started. Thought I noticed a bit of gas odor from exhaust, but could be my imagination.
Scanned with VCDS (vag-com) and got no codes. Noticed a few miss-fires on cylinder 6.
Car has the updated CTS for last 50k miles. New plugs about 5k ago. Original fuel pump, but fuel filter changed about 50k ago.
Any ideas???
Any ideas???
I'm puzzled.
I thought a bad CPS would throw a code and that the cars usually would not start.
It seems that if the car sits and cools for more than 20 minutes, the car will consistently crank for 5+ seconds before firing. If you restart within 5 minutes, the car will fire immediately.
Could it be a small fuel leak? So after you stop the engine the fuel line is gradually depressurized. Then it would be more to do with the length of time since the engine was stopped than the temperature.
It might explain why you are getting a fuel smell, although it wouldn't be from the exhaust.
