starting problem - crank times getting longer
#11
What about between 5 and 20 minutes then? Is the cranking time somewhere in between during that time?
Could it be a small fuel leak? So after you stop the engine the fuel line is gradually depressurized. Then it would be more to do with the length of time since the engine was stopped than the temperature.
It might explain why you are getting a fuel smell, although it wouldn't be from the exhaust.
The fuel smell might not be at exhaust. I just thought I smelled some gas when i got out of the car after starting.
4Driver4 thinks crank position sensor could be it, but I would expect codes?
I'm going to throw a bottle of Techron in the car and see if that helps.
#13
Still could be the crank position/engine speed sensor. I'm trying to avoid throwing parts at it.
#14
It seems that if the car sits and cools for more than 20 minutes, the car will consistently crank for 5+ seconds before firing. If you restart within 5 minutes, the car will fire immediately.
I thought a bad CPS would throw a code and that the cars usually would not start.
#15
Did yours run fine once started?
I'm getting no stumbling symptoms. Car runs fine once started. While Vag-com shows an occasional miss on cyl #6, I can't feel it.
Long crank time occurs only after car has sat for 20 minutes or more. If it sits for 5-10 minutes or less the car starts right up. Longer than 10 minutes and the cranking time incresases. First start in morning is about 5 seconds of cranking before she fires.
I checked for vacuum leaks yesterday with propane and no leaks were detected.
4Driver4 thought it was CPS, too. but I hate to throw parts at it. Maybe just keep driving it until symptoms get worse or more definitive?
#16
Car had to be flatbedded. Now I'm thinking the Crank Position Sensor was the problem after all. I'll throw one in. Wish I had the adapter to read residual fuel pressure on my gauge. Vagcom showed no injector pressure problems.
#17
I have had this issue in the past, with no codes also. It turned out to be the fuel pump. The car eventually stalled one day and would not start up at all till i had the fuel pump replaced. Fuel pump could also be a possible culprit.
#18
After throwing parts at it, I think that's my problem, too. My past experience with fuel pump failure has always been seeing symptoms of rough running at speed, because of inadequate fuel pressure.
Once mine started, plenty of fuel. I guess pumps fail in different ways.
jruell
07-24-2014 07:41 AM
0000audi
01-02-2008 11:58 PM
paulfern2000
10
08-07-2006 05:42 PM
