Strange Issue
Hello,
I have a 2003 A6 with just over 103,000 miles, last night on my way home my car went into 'limp' mode 3 times with the Check Engine light blinking. The it only lasted for about 10 seconds and maybe 5 minutes in between incident. I was very on gas and the warning chimed and then a few minutes later this happened. I have not ran a vag-com diag, but I wanted to see have anyone else experienced this also, or what should be my first corrective measure.
Thanks,
Thanks,
Here is what I see under pending DTC's:
Saturday,11,December,2010,16:41:09:12561
VCDS Release 10.6.3: Generic OBD2
Mode 07: Pending emission related fault codes
Address 10 (Engine): 3 Faults Found:
P0300 - Random/Multiple Cylinder Misfire Detected
P0301 - Cylinder 1: Misfire Detected
P0304 - Cylinder 4: Misfire Detected
Address 1A (Auto Trans): No fault code found.
Here are the results of the AutoScan:
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
Address 01: Engine Labels: 06C-909-559-ASN.lbl
Part No SW: 8E0 909 559 E HW: 8E0 909 059
Component: 3.0L V6/5V G 0001
Coding: 0016752
Shop #: WSC 02325 785 00200
VCID: 377634C23FCB
5 Faults Found:
16815 - Warm Up Catalyst; Bank 2: Efficiency Below Threshold
P0431 - 001 - Upper Limit Exceeded
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded
16685 - Cylinder 1: Misfire Detected
P0301 - 001 - Upper Limit Exceeded
16688 - Cylinder 4: Misfire Detected
P0304 - 001 - Upper Limit Exceeded
17658 - Fuel Level too Low
P1250 - 008 - Implausible Signal
Readiness: 0000 0001
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4B0 927 156 FF
Component: AG5 01V 3.0l5V USA 0910
Coding: 0001002
VCID: 70E4CFDE1A25
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 R
Component: ABS/ESP allrad 2330
Coding: 06497
Shop #: WSC 00000
VCID: 30640FDEDAA5
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 4B0 820 043 AM
Component: A6-Klimavollautomat 0105
Coding: 00110
Shop #: WSC 02325
VCID: 65CAAE8AD5E7
2 Faults Found:
00710 - Defroster Flap Positioning Motor (V107)
41-10 - Blocked or No Voltage - Intermittent
01592 - Air Quality Sensor (G238)
57-00 - Electric Circuit Failure
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4B0 959 655 Q
Component: Airbag 8.4EP 2001
Coding: 0000607
VCID: 3E7821E610F1
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 F
Component: Lenkradelektronik D01
Coding: 01002
Shop #: WSC 02325
VCID: 2F660CA2C79B
1 Fault Found:
01304 - Radio
49-00 - No Communications
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 981 N
Component: KOMBI+WEGFAHRS. VDO D11
Coding: 02262
Shop #: WSC 40232
VCID: 31620ADAD1AF
WAULT64B83N014171 AUZ7Z0B2176995
1 Fault Found:
01304 - Radio
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 M
Component: Central Lock/Alarm D37
Coding: 15885
Shop #: WSC 40232
VCID: 336E00D22BB3
3 Faults Found:
01374 - Alarm triggered by Terminal 15
35-00 - -
01559 - Drivers Door
58-10 - Can't Lock - Intermittent
01561 - Left Rear Door
59-10 - Can't Unlock - Intermittent
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0102
Coding: 00001
Shop #: WSC 00000
VCID: 2C5C1BAEF68D
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D07
Coding: 00050
Shop #: WSC 02325
VCID: 040C930E3E9D
End ---------------------------------------------------------------------
Thanks in advance for all help!!!
76 77
Coding: 0016752
VCID: 377634C23FCB
5 Faults Found:
Coding: 0001002
VCID: 70E4CFDE1A25
Coding: 06497
Shop #: WSC 00000
VCID: 30640FDEDAA5
Coding: 00110
Shop #: WSC 02325
VCID: 65CAAE8AD5E7
2 Faults Found:
Coding: 0000607
VCID: 3E7821E610F1
Coding: 01002
Shop #: WSC 02325
VCID: 2F660CA2C79B
1 Fault Found:
01304 - Radio
Coding: 02262
Shop #: WSC 40232
VCID: 31620ADAD1AF
1 Fault Found:
01304 - Radio
Coding: 15885
Shop #: WSC 40232
VCID: 336E00D22BB3
3 Faults Found:
35-00 - -
Coding: 00001
Shop #: WSC 00000
VCID: 2C5C1BAEF68D
Coding: 00050
Shop #: WSC 02325
VCID: 040C930E3E9D
there should be sticker either on the hood or on the top front of the radiator support , or check manual there is a diagram of the engine and cylinder numbers
This is a what Bentley says for 2003 A6 with 3.0L V6.
Top photo is passenger side, bottom photo is drivers side. So, cyls #1 and #4 are at front on each bank, closest to cam gear (timing belt).
