Stumbling after Timing belt/ water pump replacement
Old 02-23-2006, 06:57 PM
  #31
wgwebel's Avatar
Default Re: Not surprised you are having a problem with Champions. The wires are big money...
Okay got new Bosch Platinums and got rid of the misfire now I'm getting P1227, P1239 and P1429. First two are fuel metering and last one something to do with auxilary emissions. I'm beginning to think I've completely screwed this motor up. Guess I'll drive it a couple of days and work from there. Thanks
Old 02-24-2006, 02:53 AM
  #32
Tech Guru
4Driver4's Avatar
You have vacuum leaks somewhere. Start by fixing those.
Old 02-25-2006, 01:49 PM
  #33
wgwebel's Avatar
Default Re: You have vacuum leaks somewhere. Start by fixing those.
Well it seems to be over. I cleared the codes and have driven it for two days with the new plugs and the hesitation has disappeared and no more CEL. Just happy to report that the plugs were the problem. I am replacing all the front control arms next week to get rid of a loud squeaking front end. Thanks very much for all your help.
Old 02-25-2006, 02:04 PM
  #34
Tech Guru
4Driver4's Avatar
Awesome! Glad you got it straightened out!
Old 04-28-2006, 09:51 AM
  #35
wgwebel's Avatar
Default Re: Stumbling after Timing belt/ water pump replacement
Rearing its ugly head. I have once again reset the timing belt due to numerous air flow metering and cyl 3 misfire codes. I think I may be having a problem with the Timing belt tensioner. After I set the timing belt the car runs great for a day and then goes to crap! The last time I did the belt check I noticed that the tensioner was slow to respond and seemed to almost stick in certain spots. Could this be my problem? I'm assuming if the belt doesn't stay tight it could throw off the timing enough to toss cel codes at me. Thanks for everyones help so far!!!
mxp
01-03-2019 08:04 AM
dano-oly
11
10-11-2005 08:40 AM
S42000
Southeast Discussion
03-19-2004 01:25 PM
98a6quattro
11-22-2003 09:42 AM
Mike'9390CS
02-01-2002 04:50 AM
Quick Reply: Stumbling after Timing belt/ water pump replacement
