SUCCESS!!!! Fixed the headliner creaking in 2 minutes...
Removed the visor vanity light, took out my Molilube Chain Lube (used on the fabulous Triumph) and positioned the spray straw to the point where the creaking/squeeking was coming from and gave it a few squirts. For those who don't have motorcycles, Chain lube is a light WD-40 like spray, but it leaves a waxy, film that stops the headliner from squeeking against the metal roof beams. I assume Boeshield would work as well, it leaves a coating behind. SANITY at last! CAUTION THOUGH, chain lube is a petroleum product and will stain upholstery, DO NOT spray liberally, a little will go a long way.
I had not a creak, but a slight "buzz" (vibration)
I tried the "tighten the metal clip in the visor vanity light" trick and was sure that would do it, since the clip was definitely loose before I performed the surgery. No luck. I ended up popping out the light again and jamming a small rag inside the headliner, then replacing the light. That was in January, and the buzz hasn't returned.
Who says our beloved Audis are expensive to repair?!
I have some creaking in the rear half of the headliner when I go diagonal across driveways or ...
speed bumps, slowly. The car flexes tortiolnally, and the fit of the headliner varies a bit as it does so. I'm assuming this is normal; it is not very loud. With 4000 lbs, how rigid can that spindly Aluminum frame be??
Reggie
Rocky Mountain Discussion
05-03-2008 05:21 AM
Digger Killer
VAG-COM Discussion
09-09-2005 03:34 PM
YvesTT
08-07-2000 02:02 AM
