That sweet smell of coolant. Auxilary coolant pump, AGAIN?!?!?!
About 7 months ago I had to change out the auxilary coolant pump. When it went bad I noticed the coolant smell and the coolant was around the auxilary coolant pump under the manifold. This time I don't see any coolant in that spot. All the coolant seems to be sitting just under the blue electrical plug of the auxilary coolant pump in the rear of the engine just above the trans. Is there another connection near there that might be bad that I should check? Does it sound like the auxilary coolant pump again?
Also I noticed some oil or something on and around this hose.
<a href="http://photobucket.com/" target="_blank"><img src="http://i28.photobucket.com/albums/c243/ninjaed/leak2.jpg" border="0" alt="Photobucket - Video and Image Hosting"></a>
its the hose on the passangerside front of the manifold. It is directly behind the DV and goes through the slot on the manifold. Is this something I should worry about?
Thanks again for all the help!!!
SkiBum2
01-26-2011 04:09 AM
AEGA4
12-05-2003 05:27 PM
DannyA4
03-19-2001 07:14 AM
