Synthetic oil every 10k miles?
Since I'm used to having to chage my oil every 5,000 or 7,500 miles, it's a bit strange to think that Audi only requires the oil to be changed every 10k miles. My service rep said that since I own my car, I might want to bring in my own Mobile 1, and have Audi use that when the oil is changed. Thoughts?
If I switch to synthetic, do I need to have the oil system flushed to remove all of the conventional oil first?
5K, not 10K as warranted. I bring my own Mobile One in for the oil changes. It is more expensive this way (an extra $35 each 5K) but I like the "insurance dividends" it pays me in knowing my car is in better than normal care. The Audi dealer said that he sees probably 95% Mobile One for those requesting a synthetic and 5% "other" synthetics used. You do not need to change/clean out the old "dino" oil. Both are compatable with one another. Good luck..
Here is an informative thread:
<a href="https://forums.audiworld.com/s4/msgs/407320.phtml">https://forums.audiworld.com/s4/msgs/407320.phtml</a>
the test. Duralube can beat most oils in a test they use, I saw it on TV. ;-)
as applied to a real engine running in real life.
So make of it what you will. I've heard no reliable info suggesting new Mobil 1 is other than 100% synth, but if in doubt IMO Amsoil & Red Line are as good, maybe better in some cases (eg Amsoil for extended drain interval).
FriscoTT
07-13-2001 08:15 AM
