Technical Question
I have searched the A6 archives and have not found a thread with regard to a problem with my Mother's '99 A6 2.8q. My Mother's car has approximately 60K on the odometer and has recently began to exhibit a power dip while cruising at moderate speeds (~45-50 mph). I have noticed that the fuel cut off during cruise is becoming more pronounced and appears to be responsible for this power dip. Is there a suitable solution to this problem or is it part of the normal aging process for the car.
Thank you for the advice.
Cordially,
John J. Szobocsan
NM TT #11
'05 S4 Cabriolet on order
Cordially,
John J. Szobocsan
NM TT #11
I have not noticed it at higher rpms, i.e., highway cruising at 70 mph+. The car is maintained beyond the required service and at 58K the 60K service was performed. The fuel filter and air filter was changed.
-J
-J
I wonder if the ECT is being reported wrong to the ECU.
Dirty injectors come to mind as do spark plugs (which I imagine where recently replaced). I think Techron is in your future.
I would also suggest a throttle adaptation.
