temperature gauge reading faulty
Finished installing a6 c5 1998 year instrument cluster into audi 100 c4 1992.
managed to get everything working perfect but temperature gauge seems to be reading very wrong. if engine temp is 90 (vag com showing via ECU not cluster) then gauge shows between 105-120 celcius.
temperature sender is working, because when i drove my car to garage, temp was 87-90 like it always have been.
is there any possibility to adjust temperature gauge on that instrument cluster ?
Silver
Silver
Perform an output test on the instrument cluster. Every needle will perform a sweep from min to max, then hold in the center. If any of your needles aren't centered, either the needles need to be reset if possible, or the servo motors in the gauges need to be replaced.
skystrick
05-27-2015 05:28 AM
N X B 3
04-10-2006 11:57 PM
TTeleven
12
03-01-2003 09:43 AM
