Is there any way to disable the Xenon Headlight Range Control through Vag-Com?
I've been getting the range control malfunction warning on my dash almost every trip I take over 10 miles or so... The beep is loud and obnoxious, and I don't like looking at the icon. I scanned the car and got:
I did a search and found this thread over at the Vortex:
http://forums.vwvortex.com/showthread.php?4748081
I tried recoding Adaptation 2 in Address 55 from 1 to 0 because it worked for that guy, but it did not work for me.
I know the problem is there, and I will fix it when I have some time, and/or money if I have to take it to a mechanic... For now though, I would just like to disable the warning or even the range control altogether. Any thoughts?
Address 55 -------------------------------------------------------
Controller: 4B0 907 357 C
Component: dynamische LWR D05
Coding: 00020
Shop #: WSC 02325
1 Fault Found:
00776 - Level Control System Sensor: Left Front (G78)
28-10 - Short to B+ - Intermittent
Coding: 00020
Shop #: WSC 02325
1 Fault Found:
It's on the lower control arm Left front side.
Here's somewhat what it looks like.
With the driver side front wheel removed, the level sensor can be spied attached via a long vertical black plastic arm to the front lower control arm (nearest to the control arm bushing at the subframe--shown here just to the left of the red shock absorber), thusly:
I think I will try this as well. If the annoying light and beep goes away then I can address the leveling situation at a later time.
Thanks for all the input!
You most likely have a wiring issue--as in the sensor's wiring is shorting out. Start by checking the insulation of the sensor's wiring for any indication that the wiring insulation might be compromised starting at the sensor and tracing the wiring back.
00776 - Level Control System Sensor; Front Left (G78): Open or Short to Ground
I also noticed that the part where the long black vertical arm attached to the upper shorter arm that moved at the sensor was stuck in place pretty good. So, I sprayed the nut holding on the long arm with some liquid wrench, and cleaned it up a bit with a wire brush. Then I removed the long vertical arm with a 10mm socket and needle nose pliers to hold the other piece behind it in place.
Once apart, I applied a bit of grease to the inner face of the nut and the bolt so that it would move freely with the upper arm. Then, I drilled a small hole into the lower part of the arm, and bolted it back on at the top, backing it out about a quarter turn from fully tightened to allow it to move with the upper sensor arm. I shaved a bit of the plastic bushing that it fits onto at the control arm so that I was able to slide the lower part back on, and then I secured it by running a zip tie through the control arm bracket and the small hole that I drilled in the vertical arm...
I went on a short test drive, and so far so good... If the warning light comes back then I will look further into the wires at the sensor, and possibly consider pulling fuse 10.
Thanks again!
