Is there a maximum mileage after which you shouldn't change the tranny fluid?
Old 11-01-2007, 03:15 PM
1st car in my name's Avatar
Default Is there a maximum mileage after which you shouldn't change the tranny fluid?
There seem to be a lot posts lately about changing the auto transmission fluid. I want to do mine, but am worried since I don't know if it has ever been done to the car. I bought the car at 111k so don't know anything before it, but in the 40k I've driving it, it has never had a tranny fluid change.
Is the preventative fluid change still worth it or do you think it might cause more bad than good?
Old 11-01-2007, 03:48 PM
A8CT's Avatar
Default For what it's worth, I have examples of both in my fleet:
2000 A8 bought at 50k and have changed twice (now 105k)
2000 A8 (wife's) bought with a 140k and just changed filter, re-used fluid to keep viscosity the same. Now has 150k.
Both shift exactly the same. It killed me to not change the fluid but I knew that it had never been changed before.
That was the advise given to me by several A8 guys.
Bob
Old 11-01-2007, 04:11 PM
Tech Guru
4Driver4's Avatar
Default Did the A6 when it started to shift lazy at 150k. Just do it.
Just remember: flushing is for toilets, not transmissions, and be sure to change the filter.
Old 11-01-2007, 05:13 PM
tozoM8's Avatar
Default I would not change it, it will be all downhill from there.
I would check the level, but leave it alone.
Old 11-01-2007, 05:32 PM
Tech Guru
4Driver4's Avatar
Based on....?
Old 11-01-2007, 05:36 PM
CTT4.2's Avatar
Default I'm in the same boat, thought about chaging it butit seems when
people do that, the tranny goes soon after.
At least based on about 3 posts here or so.
Old 11-01-2007, 05:38 PM
Kwatro's Avatar
Unless you're driving a Dodge Minivan...but that's for a different forum...
Old 11-01-2007, 05:41 PM
tozoM8's Avatar
Default Reputable transmission shop would never change the fluid on a car that never been serviced before.
AAMCO does.
Old 11-01-2007, 05:42 PM
Tech Guru
4Driver4's Avatar
What Dodge minivan trans lasts to 150k...or even 50k - lol. Those poor people.
Old 11-01-2007, 05:54 PM
Tech Guru
4Driver4's Avatar
Any car? Audi? I'm not buying it. If you replace the filter and use the right fluid, no problem.
Quick Reply: Is there a maximum mileage after which you shouldn't change the tranny fluid?
