Is there a suspension kit for a 2.7T w/ Sport Suspension,
well i can almost raise my kw v1 to about stock sport hight if i wanted to...they might be about a half inch lower i think it's about 1.7in lower than stock non sport suspension...currently running 25 1/2 front and 26 rear.<ul><li><a href="http://www.hpamotorsport.com/index1.htm">http://www.hpamotorsport.com/index1.htm</a</li></ul>
I checked with HPA on the KW's. They will lower the car an additional 20mm from the Sport Suspension height. HPA suggested checking to see if Bilstein (or others) have a strut only (keep the Audi Sport springs). Any thoughts?
check and see what your current hight is..ground to fender front and back...then we can compare notes...i didn't get a chance to measure this before the suspension was installed.
I did the same thing. Didn't measure before installing an Abt kit (H&R/Bilstein). Problem is I'm too low now. This is compounded by the fact that I have an MTM exhaust and the larger pipes take up even more clearance. I have a friend with a stock 2.7T Sport Suspension. I will measure his this weekend and post here.
that's the main reason i didn't go w/ the abt kit...looked too low especially w/ my set up, i'd def rub in front. W/ the kw's i think i can go up to stock sport hight..
Soner-O
Audi A3 / S3 / RS 3
05-15-2006 04:58 PM
ijflexi
06-17-2004 04:41 PM
Black Sunshine
06-24-2003 10:00 AM
nicky
02-13-2001 12:07 AM
cpayne
10-27-2000 08:10 PM
