Is there a write up on replacing/repairing cooling fan clutch?.....
put lock carrier in service position. It's a little tight but doable.
If you don't get the special tool(chopsticks) to hold pulley while you unscrew the fan, you can remove the serpentine belt with a 17mm socket and stick an allen wrench into the holes to keep the tension off the belt. Hold the fan pulley with a strap wrench. Nut is reverse threaded.
Once off, your remove the fan from the clutch and put the fan on the new clutch.
Tourette(AFC2.812v)
12v V6 Discussion
02-23-2005 08:39 AM
0700
06-08-2002 09:36 PM
