Tie Rod End help!
Tie Rod End help!
Noticed both the rubber boots on my tie rod ends were torn. Ordered two new Meyle s from ECS. Got everything apart, including loosening the lock nut that locks the 18mm adjustment hex. Only problem, the tie rod end will not unscrew from the 18mm adjustment hex, which I obviously need to do to screw the new one in. It seems like the tie rod end it practically welded in (stuck by corrosion I guess.) I sprayed half a bottle of penetrating oil at the hex and let it sit a few hours, spraying in more in between. Didnt help.
How can I get the end loose?
BTW, I have a compressor and air hammer if that helps
The entire rod? as opposed to what? You just want to remove the tie rod end itself
It has a locknut that stops the travel of the tie rods threads. 5/8" and a 7/8" wrench should suffice.
PB blaster spray works the best, btw.
