Timing belt: replace, or cross my fingers?
#12
in the winter or sell the car, even if you are not in a position to do so. Also...the car will be worth slightly more or be easier to sell with it done.
#13
To maximize your maintenance dollar, change the belt the day before is breaks. ;-)
I think my choices are to change it asap or not at all. At 255k, it does have some valve, but how much can the car be worth at this point?
#14
I for one do not think mileage is a very good metric for timing belt wear and, more importantly, as an indicator of when the belt is about to go. 2 years ago?? Are you kidding? That thing should have tons of useful life left in it. I can't believe you are even considering it now.
I did mine at about 90K because I knew that my expected life of the car was to about 180k. It is possible I could keep it longer than that.
But at the cost to do it again (probably 1k) vs. the expected value of the vehicle at that time (probably 2k), I don't see it ever getting done again on this car.
#17
So you're suggesting he knows the answer or what?
#20
this lets you fix or replace on your schedule, not when you have to do something...which is guaranteed to happen when the car is 200 miles away from home, you have final exams, and some audit due for work...
