Tire removal
Tire removal
Ok new to audi world and audi car.
1999 a6 how do you remove the wheels on this car .
5 lug nuts and one center bolt . i removed lug nuts nothing happened.
Do i need to remove center bolt. alloy rims not hub caps.
Trying to fix leaking washer fluid container inside fender well.
Thank you.
Thank you.
This is the collar bolt which holds your constant velocity joint in the hub. Do not touch it for the the procedure you are trying to conduct.
Sometimes the windshield reservoir tanks crack with time. They can be found on Ebay for cheap if that turns out to be what is wrong.
yes it is the windsheild reservoir that is leaking but looks like pump seal on tank.
know better when i remove it .
If whacking the tire with a big hammer doesn't free the wheel, you can usually break the corrosion between the wheel and the brake rotor/hub by doing this. Loosen the lug bolts/nuts and lower the car to the ground. Then drive the car back and forth a few feet and hit the brakes hard each time. Normally does the trick.
Then jack up each corner to remove the wheels. When replacing the wheels, it's a good idea to use anti-seize on the mating surfaces between the wheel and the rotor and around the hub.
alloy wheel is seized to the hub. Lie on your back and kick the bottom of the tire with the wheel off the ground. Or lower it, withy lug nuts off, very, very slowly and let the 1000 weight of that corner crack the corrosion.
Nothing holds the wheel on except those 5 lug nuts.
G
G
rampart03
08-08-2004 04:30 PM
