Tires balanced and rotated and ride is way worse than before...
#15
Well, since those also need to be changed...
(given I am almost 85k on original shocks and springs) probably to Koni's, that's not a big concern right now either. ; )
John in Cincy
John in Cincy
#18
Re: Done. Don't think that is it. Think it is the wear pattern.
I agree with John. I have had this experience on more than one occassion (one would think I'd learn) and even on motorcycles. If you let the tires remain unchanged when they are finally rotated the wear pattern is too far gone and makes things really bad. Not to say you shouldn;t check the other suggestions but be prepared for this outcome.
Goodluck
Goodluck
#20
Something about Cincinnati roads...
Had same problem with my Conti's on my '01. Tried three sets before satified. First ones wore out at 14k. Had similar issues with P6's.
Need new tires on wife's E500 wagon after 18k (and doesn't drive like I do). Benz mechanic tells me Mich's are the only ones that get decent wear.
OEM's tires suck!
OEM's tires suck!
