Told the dealer i could not Code my Trans
Old 05-05-2004, 02:34 AM
Junior Member
NJ4.2GUY's Avatar
Default Told the dealer i could not Code my Trans
they said they cant find anything wrong and the computer is fine.(no fault codes) but i could not change the code with VAG any ideas what i should tell them or look for ?
Old 05-05-2004, 03:51 AM
duodallas's Avatar
Default Have you asked on the VAG forum?
It is about the easiest recode unless something in the SW is not right.
Old 05-05-2004, 04:58 AM
Junior Member
NJ4.2GUY's Avatar
Default Did the locks
i coded my remotes to roll up and down the windows and that took no problem it was odd every time i went to change the code and hit "Do It" It went back to the screen with the old code
Old 05-05-2004, 05:55 AM
Senior Member
bostoned's Avatar
I've done several re-codes, it has done different things each time. Your issue doesn't surprise me.
Old 05-05-2004, 06:01 AM
andrec's Avatar
Default What year is your A6? I couldn't recode my '02 A6 4.2 either until I upgraded my Ross-Tech cable...
to their Hex-com version. Check out the Ross-Tech website for details.
The older/original version of the Ross-Tech VAG cable (mine was from AWE-tuning) did not support all of the functions. Once I upgraded to the new Hex-Com cable, everything functioned as advertised on their website.
Hope this helps.
Andre
Old 05-05-2004, 10:20 AM
New Member
2.7TToronto's Avatar
Default Try trans coding without running the engine...
It won't accept the code if the engine is running.
Old 05-05-2004, 05:11 PM
rdsii's Avatar
I got it to work on my car
Old 05-06-2004, 07:55 PM
Junior Member
NJ4.2GUY's Avatar
ok i will try that i did have the engine on
Old 05-07-2004, 11:59 AM
Junior Member
NJ4.2GUY's Avatar
Default I GOT IT!!
I had to do it with the engine off ..Thank you very much 2.7T Toronto!!!
Old 05-07-2004, 12:33 PM
andrec's Avatar
Glad you got it. Drive it around for a while and give us some feedback.
Quick Reply: Told the dealer i could not Code my Trans
