Is the Torsen system on the Quatto IV capable of diverting more power to the rear wheels?
This may seem like a stupid question, but I read that the "Torsen" system is a torque-sensitive electronically-controlled differentials between the front and rear tires. If it's electronically controlled, then can it change the power distribution between the front and rear? I searched for other posts on this, but didn't find much.
yes it can, but its not electronic, its fully mechanical (link enclosed)
This is the device "between the axles." Our cars are able to bias up to 66% of torque linearly front or back. Normally, the ratio is 50/50. The front and rear axles have open differentials with Audi's version of traction control called EDL in concert with the ESP stability control system.<ul><li><a href="http://www.torsen.com/products/T-1.htm">Torsen diff</a></li></ul>
The center diff is fully mechanical. The front and rear diffs are open, using the ABS in reverse
to detect wheelspin and slow the spinning wheel while directing power to other wheels. Bias is usually 50/50 front to rear. With Quattro IV, up to 75% of power can be shunted front to rear, and up to 67% to any one wheel. Some older versions of Torsen based Quattro systems could send up to 78% of power to the front or rear, but didn't have the tricky electronic diffs of QTR IV. The electronic diffs operate up to 55mph in a QTR car, and around 45 in a Front Trak car. The function then disengages to prevent brake pad meltdown.
All types of VAG AWD systems:
http://www.daniil.dds.nl/skoda/vag-4wd-types.html<ul><li><a href="http://www.fortunecity.com/silverstone/lancia/58/technical_school/traction/tech_traction_4wd_2.htm">Other types of AWD</a></li></ul>
that part about 67% to any wheel i don't think is right. 67% to either differential, but a open diff
erential can only tranfer 50% of power it receives to either of it's axles. if one of the axles starts slipping it drops even more. that's where the edl comes in, it brakes to transfer torque, but is also wasting torque in braking to transfer torque to other side of differential.
i don't know if this makes any sense to you, but i think you can only transfer 33% of torque to any wheel.
We had a Torsen rep give us those figures in a class once. You can find the 75%
figure for max front to rear power distribution many places. What I recall is that if you have 3 tires on glare ice (no traction), the EDL absorbs 33% of available power in braking the wheels with no grip (it doesn't completely halt them), while the remainder gets channeled to the wheel with grip. If I can find my old workbook from that class, I'll scan it for you.
an open differential can only apply equal torque to both axles(see link)
and since it can't apply 100% to both, best it can do is 50% split to each axle if i am understanding correctly. and 50% of 66% from center differential(i thought we have a 2 to 1 bias torsen) is 33% to a tire.
i like to see info if you have it. i have seen lots of people say the same thing you have but no explanation of how.
from my figures if you used all torsen differentials(front,rear,and center) and all where 4 to 1 bias(transfer up to 80%) you could transfer 64% of torque to any wheel.<ul><li><a href="http://auto.howstuffworks.com/differential6.htm">http://auto.howstuffworks.com/differential6.htm</a</li></ul>
FSI Power
A4 (B7 Platform) Discussion
01-18-2006 09:11 PM
Explain me what is the deal with the quattro system on TTs. I heard that it is different from bigger
Mad AR
05-07-2002 10:30 AM
Silver4ringer
9
01-11-2002 06:21 PM
