Tough week for an Audi owner...
#12
Was it the air temp sensor? Or was this jist one on the list that is still nagging at you? Anyways, goodluck man, my advice, tackle the main problem head-on, pass inpsection, then work on the plate surround, scuff mark. And yes, I did see Iron Man, it was a good movie with cool special effects, but it was painfully obvious that Audi and Burger King and a few other sponsors donated some cash flow for the technical work. LMAO
#13
(below)
BTW, you may want to check your sig. I think you've got a typo ("debadfed").<ul><li><a href="https://forums.audiworld.com/a6/msgs/780577.phtml">https://forums.audiworld.com/a6/msgs/780577.phtml</a</li></ul>
#14
could it be that the 710Ns set off a silly chain reaction of codes. How, I dunno, maybe bad install, (although you did say a competent machanic), but its suspect that it came on "right after" you upgaded the DV's. Good luck with this one man. Forced Induction is a PIMA, but fun when it snaps you neck back. Also, my first step when a code pops, is "three clicks" on fuel door. Couldnt hurt to clean MAF sensor too??
#15
At this point, no reason to suspect the BPVs - I've discussed the history with the mechanic (VERY competent) and they are not considered valid suspects. The codes it's been pulling have changed somewhat over time, but the current one (P0113 - bad inlet air temp sensor) has been consistent. So, given the fact that this is the only one left (we've reset it several times and this is the only one that keeps coming back), I'm not inclined to suspect anything other that what we're now focusing on: bad IAT sensor or a faulty/loose connection.
#18
...which, OF COURSE, was delivered. Thanks to all for the commiseration.
I think the love affair will be renewed once I get her detailed again. Been a while since she's had her legendary shine. Other than the obnoxious CEL light, she still runs like a champ.
I love my new car
04-22-2011 08:16 AM
