Transmission "Lockout"
Our 2000 A6 2.7T has the tiptronic transmission. The car starts, but won't get into gear. Is it possible that something electronic has locked the transmission out? I'd like to get it running enough to get to a service area and have someone check it. Any leads or common problems would be helpful.
Thanks!
Thanks!
The lever won't go into gear or what?
AudiWorld Expert
...it is red when in park, and goes off when your foot is on the brake. If your foot is on the brake and it stays on, your brake switch need to be replaced.
Low cost item ($20-25 at the dealer) and not too hard to replace.
you can have a short that blew the tip board
or
the board is bad
or
tcm is bad
ot the magnets is bad
check for shorts from the VAG
if you need to move it you have to trick the tranny why it is in between the N and the gear you want, to prevent it from locking so you can drop it into gear when it is started.
or
the board is bad
or
tcm is bad
New info:
The car sometimes goes in Reverse and can move on its own power. Forward gears seem to be the problem. So the gear selector moves. I'll listen for the solenoid sound, but I don't remember anything distinctive.
also, was this issue released as a TSB by Audi?
Thanks all
Thanks all
AudiWorld Expert
...following this post: <a href="https://forums.audiworld.com/allroad/msgs/172809.phtml">shift bezel removal and brushed finish</a>. This is for an allroad, but same thing for any C5-platform car.
If you need a replacement, you cannot buy a new board only...it comes as part of the metal bezel shift surround. I might have a spare one in the basement (from a donor shift bezel from the brushed shift bezel mod). Let me know if you need it.
