Tried to find in "Search", but couldn't find something that would help. Oxygen Sensor Question..>
My Check Engine came a while ago. Had a "good" guy check it VIA VAG. It showed that the Oxygen Sensor didn't like something. I understand that the oxygen sensor is an Emission related thing, but what does it exactly do? Anyways, also i read something about some "CEL" any knowledge what that is? The funny thing is that the Check Engine turned off after i started the car for two times. Before i Did bring it to check on VAG... It sais its the two front ones, and my MPG is terrible now!.. Guess because of the sensors...
Also, should i change 1 sensor, or two front ones at the time?
TIA
TIA
<ul><li><a href="https://forums.audiworld.com/a6/msgs/568631.phtml">https://forums.audiworld.com/a6/msgs/568631.phtml</a</li></ul>
You ecu checks for fauls with a routine. So it must have not seen the same error and that is why CEL went off, but it probably wouldn't hurt to replace them.
How many miles on your car?<ul><li><a href="http://www.vastperformance.com">VAST</a></li></ul>
tell the ecu to adjust the quantity of fuel that the vehicle injects to the engine...it's more complicated than that but that's the basics...
Something else is going on to cause the car to run rich. Is it possible that you have a boost leak? I bet the code you got was "out of range".
Saturday, 02 July 2005, 10:03:41
VAG-COM Version: Release 504.1-UD
Chassis Type: 4A - Audi 100/A6 C4
Scan: 01 02 03 08 15 17 25
Address 01: Engine
Controller: 8D0 906 266 A
Component: 2,8l V6/2V MPI OBD2 D03
Coding: 01042
Shop #: WSC 23247
No fault code found.
Readiness: N/A
Address 02: Auto Trans
Controller: 4A0 927 156 AK
Component: AG4 01K 2.8l2V USA D21
1 Fault Found:
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Address 03: ABS Brakes
Controller: 4D0 907 379 G
Component: ABS/EDS BOSCH 5 7590
Coding: 0265109001
Shop #: BB 37590
Address 08: Auto HVAC
Controller: 4A0 820 043 K
Component: Klima-Vollautomat D05
Coding: 00162
Shop #: WSC 23247
Address 15: Airbags
Controller: 8A0 959 655 D
Component: Airbag V AUDI D00
Coding: 00127
Shop #: WSC 02324
Address 17: Instruments
Controller: 4A1 919 035 CJ
Component: C4-KOMBIINSTRUMENT D20
Coding: 00262
Shop #: WSC 40869
No Faults Found
or DTCs not supported by controller
or a communication error occurred
End
Saturday, 22 October 2005, 21:52:55
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 08 15 16 17 35 36 37 45 55 56 76
Address 01: Engine
Controller: 4B0 907 551 T
Component: 2.7l V6/5VT G 0001
Coding: 06752
Shop #: WSC 02325
WAUED64B41N069171 AUZ7Z0Y1609053
2 Faults Found:
17521 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
17539 - Oxygen (Lambda) Sensor; B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
Readiness: 0000 0000
Controller: 4B0 927 156 DJ
Component: AG5 01V 2.7l5VT USA 1617
Coding: 00002
Shop #: WSC 00000
Controller: 8D0 907 389 E
Component: ABS/ESP allrad D56
Coding: 06397
Shop #: WSC 02325
Controller: 4B0 820 043 L
Component: A6-Klimavollautomat D64
Coding: 00160
Shop #: WSC 02325
Skipping Address 15-Airbags
Address 16: Steering wheel
Controller: 4B0 907 487 D
Component: Lenkradelektronik D02
Coding: 00102
Shop #: WSC 12345
Controller: 4B0 920 981 G
Component: C5-KOMBIINSTR. VDO D12
Coding: 02264
Shop #: WSC 03163
Address 35: Centr. Locks
Controller: 4B0 962 258 J
Component: Central Lock/Alarm D33
Coding: 15885
Shop #: WSC 02325
7 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
Address 36: Seat Mem. Drvr
Controller: 4B0 959 760 B
Component: Sitzmemory R1 F 0101
Coding: 00001
Shop #: WSC 00000
Address 45: Inter. Monitor
Controller: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00101
Shop #: WSC 02325
Address 55: Xenon Range
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00006
Shop #: WSC 02325
Address 56: Radio
Controller: 4B0 035 195 A
Component: Radio D00
Coding: 00116
Shop #: WSC 23341
End
Address 01: Engine
Coding: 01042
Shop #: WSC 23247
Readiness: N/A
1 Fault Found:
Coding: 0265109001
Shop #: BB 37590
Coding: 00162
Shop #: WSC 23247
Address 15: Airbags
Coding: 00127
Shop #: WSC 02324
Coding: 00262
Shop #: WSC 40869
No Faults Found
End
Address 01: Engine
Coding: 06752
Shop #: WSC 02325
2 Faults Found:
Coding: 00002
Shop #: WSC 00000
Coding: 06397
Shop #: WSC 02325
Coding: 00160
Shop #: WSC 02325
Coding: 00102
Shop #: WSC 12345
Coding: 02264
Shop #: WSC 03163
Coding: 15885
Shop #: WSC 02325
7 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00955 - Key 1
Coding: 00001
Shop #: WSC 00000
Coding: 00101
Shop #: WSC 02325
Coding: 00006
Shop #: WSC 02325
Address 56: Radio
Coding: 00116
Shop #: WSC 23341
End
