Turbos Replacement for 2002 Audi A6 2.7t
Old 10-27-2013, 10:27 AM
  #11
Superfastdeluxa6's Avatar
It's a head gaskets issue this car is know for According to manufacturers aka Audi
Old 10-27-2013, 04:18 PM
  #12
I have the same problem my turbos are leaking and my headgaskets are leaking as well and I drove 3000 miles it be ok as long as u don't think ur in a race track like I And intent think sometimes but it should be ok get it fix ASAP tho let also let me kno what price u get for the replacements of those turbos
Old 10-27-2013, 07:14 PM
  #13
Tech Guru
4Driver4's Avatar
3000 with blown head gaskets? Unpossible.
Old 10-28-2013, 03:49 AM
  #14
Indeed it is it sweat more when you push and I been push it I'm trying to lay off now b4 I kill her which I really don't want too but I think it's blown it just leak very small amounts something Audi did wrong tight the head a Lil more and it probably stop
Old 10-28-2013, 09:18 AM
  #15
GTA_Driver's Avatar
I don't think Audi is known for blown head gaskets...
Old 10-28-2013, 09:20 AM
  #16
GTA_Driver's Avatar
You have a head gasket leak? How do you know? And what did Audi do wrong, did you ever have the heads removed for any repair, or is this an untouched stock engine?
Old 10-28-2013, 05:30 PM
  #17
It's not blown but they all leak from the head for some reason idk And might be a spec issue but they do I have the same problem wit mines when I replace them in and a 1/4 pound more then spec to see if that does the job
Old 10-29-2013, 02:17 PM
  #18
johnkk's Avatar
Default valve cover gasket not head gasket
headgaskets seldom leak oil, it's the valve cover gaskets that frequently leak. The valve cover sits on the head and I think you're confusing the issue.
Old 10-29-2013, 03:17 PM
  #19
SloopJohnB@mac.com's Avatar
Do not tighten head bolts 'a little bit more.' Do some research. Those are likely angle tightened bolts or torque-to-yield…you tighten them more you might just break them.
Old 10-29-2013, 08:14 PM
  #20
I am I'm doing it yet I got other things I wanna do be for that since it ain't that serious
Quick Reply: Turbos Replacement for 2002 Audi A6 2.7t
