turn signals
Old 02-10-2009, 09:53 AM
  #11
Member
audiphobic's Avatar
Default Re: 4driver4, Press, BD, lastls1 and STFA all say hazzard switch.....
It's not so much that I think that it is something else. Just trying to eliminate all the other possibilities.
I just read the tech article about replacing the turn signal stalk and he originally thought that the hazard relay switch was the problem. Only to have it replaced and the problem still existed.
https://www.audiworld.com/tech/elec.html
Old 02-10-2009, 09:57 AM
  #12
Grapeking's Avatar
Default Maybe none of us is understanding what you are asking of us - but if we are, you've recieved
multiple responses from various seasoned C5A6 veterans and they're all in agreement on this. I'd go with their collective wisdom if I were you!
Old 02-10-2009, 09:58 AM
  #13
Tech Guru
4Driver4's Avatar
Default The hazard relay is cheap and easy to replace. Start there.
If the problem persists, park the old relay in the glove box for a spare and change the signal stalk.
It could be either, but history has shown a much higher failure rate on the relay.
Old 02-10-2009, 09:59 AM
  #14
Tech Guru
4Driver4's Avatar
BTW, this forum reads much nicer if you take the time to edit the subject lines in your responses.
Old 02-10-2009, 10:05 AM
  #15
Member
audiphobic's Avatar
Default Re: Maybe none of us is understanding what you are asking of us - but if we are, you've recieved
No, I totally appreciate all the responses. Just want to make sure. Thanks to everybody that had answered my post. The members here are the best!!!
Old 02-10-2009, 10:06 AM
  #16
Member
audiphobic's Avatar
sorry 'bout that...I'll do better next time
Old 02-10-2009, 10:07 AM
  #17
Member
audiphobic's Avatar
Thanks for all the help...I'll start at the hazard relay...
Old 02-10-2009, 10:19 AM
  #18
Member
audiphobic's Avatar
Default 7 pin or 10 pin...
'01 A6 2.7T
Is it the actual hazard switch? Sorry for being sooo stupid.
Old 02-10-2009, 03:48 PM
  #19
Fear the Miata!
Press's Avatar
Default pull the old one out....most dealers have that part in stock....takes 5 minutes, even for a n00b
like me....8^)
dparnas
13
05-13-2012 03:25 PM
sidespar
12-23-2009 05:08 AM
Whitjr
10
03-25-2008 04:59 PM
darko886
03-12-2008 05:46 PM
Asicks2.7T
01-21-2008 08:18 AM
Quick Reply: turn signals
