Update on transmission
I plugged the VAG in and got the following fault code 17114 "gear ratio monitoring: incorrect gear ratio" then P0730-35-10.
anyone have any ideas or suggestions?
thanks in advcance,
Craig
thanks in advcance,
Craig
* Low ATF.
* Clutch slipping or solenoid valves soiled or bad.
* Vehicle Speed Sensor (VSS) faulty.
* Sensor for transmission RPM faulty.
Well I think I can rule out the low ATF, no leaks at all. so it may be one of the others.
Thank you very much! Now I at least have an idea what to expect when I take it in. Any thoughts on how painful this will be?
skittzzz
04-05-2014 01:51 PM
reinstone79
04-12-2010 12:04 PM
vcarter911
17
11-09-2006 10:53 AM
avtiger
12v V6 Discussion
04-19-2005 05:16 AM
