upper control arms ?
I could use a little helpful information from anybody...I have a 2000 a6 2.7t and the upper control arms are toast. Will this be something I can do on my own and then take in to get an alignment or is this totally out of my control and need to take to a shop?
Yes, ....BUT
The pinch bolt is either awful or not too bad.
What i found more difficult - and disconceerting - was the amount of force it took to pull the entire strut back up so that the pinch bolt could be re-installed. Possibly I should have disconnected more of the lower suspension than I did. bentley was nto helpful here.
But you can do it.
make sure you have a 16mm socket and wrench.
Grant
But you can do it.
Grant
second the 'BUT' part - when I was doing my CV boots, I tried EVERYTHING to
get the pinch bolt out. Note, like you I have a 2000. I had never needed to pull the pinch bolts (this was a year ago so the car was 7 years old at the time). Pinch bolts were/are absolutely frozen in place. I tried soaking with PB Blaster for a week before the job, hitting with a 5 lb. sledge up to 500 times (yes, I was counting) etc. Couldn't get them to budge. I did not try heat, just opted for the alternative approach to get the CV boot job finished.
Hopefully your pinch bolts go better.
Hibiscus Red S4
10-19-2006 09:47 AM
skiracer
08-13-2005 03:41 PM
AndyA6
9
06-23-2004 06:19 AM
technics100
06-30-2003 10:24 AM
