V1 / Passport 8500 Hardwiring to the Autodimming/Compass Internal Mirror
#11
If colors of the wires below the connector match, then double check with a voltmeter and you are good to go...
#14
Power goes off if you lock the car, and goes off in half an hour if you don't lock the car. Didn't have to cut or drill anything.<ul><li><a href="https://forums.audiworld.com/a6/msgs/291006.phtml">https://forums.audiworld.com/a6/msgs/291006.phtml</a</li></ul>
#15
and apply the things not deep enough into the space they will lurk in: once you crimp them, they are not coming off, and if you can't refit the cover you are out of luck .. I screwed up this way and in the process of removing the taps, broke the ground wire as well
it was a bad time all around for me.
I also found these radio shack taps didn't make a very good connection even after smashing them down with pliers, I still got intermittent power.
I hate mods that go wrong.. no criticism intended of the designer of the mod. I should have thought harder while doing it.
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
RostyVyg
Audi allroad
03-09-2004 07:38 AM
RostyVyg
03-05-2004 08:18 AM
RostyVyg
03-04-2004 02:41 PM
