vag-com code on my 02
So here is another question on this A6 I bought a few weeks ago.
Car in question is a 02 A6 3.0 tip/quattro with 116K on the clock.
So when I bought this car it had a check eng. light. I scanned it over with vag-com, and cleared all codes. There were alot with the alarm system. NO trans codes, and a few eng codes. Now car had just recently had a new battery installed, figured this might have todo with the alarm codes.
Anyhow, I cleared all codes, after logging them. Drove the car 200 miles and check eng ligght came back on. Figured ahh now I can start some diagnostics, and have a better foundation to work with.
Codes that came up on the eng. are
16805- Warm up catalyst;Bank 1 : efficiency below threshold.
......P0421-001-- Upper limit exceeded-MIL ON
16815- Warm up catalyst;Bank 2 : efficiency below threshold.
......P0431-001--Upper limit exceeded-MIL ON
What are these codes showing.. I Dont have a shop manual yet, Had some unexpected bills. But should have a manual in a week or two..
Thank you in advance. James K.
IIRC they are spacers for spark plugs that can be used on rear O2 sensors to pull them out of the exhaust flow a bit thereby not picking up as much O2. Makes your ecu think your cats are still doing their job. Goggle anti-foulers and you'll get the idea real quick. I have similar codes on the '01 and have looked into this. Similar codes but not the same because no pre-cats on the 2.8?
thank you guys.
Well I'll have to google it.
I was on theway home tonight and had a short spell of low power tonight.
there was a spudder/miss or lack of fuel, not sure which. Came home scanned the car with my Vag-Com Hex+Can. Got the following , some are new and were notthere the last 2 scans.
Monday,01,March,2010,18:43:52:41832
VCDS Version: Release 908.1
Data version: 20091018
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
VIN: WAULT64B32N
Address 01: Engine Labels: 06C-909-559-ASN.lbl
Part No SW: 8E0 909 559 D HW: 8E0 909 059
Component: 3.0L V6/5V G 0003
Coding: 0016752
Shop #: WSC 02325 785 00200
5 Faults Found:
16805 - Warm Up Catalyst; Bank 1: Efficiency Below Threshold
P0421 - 001 - Upper Limit Exceeded - Intermittent - MIL ON
16815 - Warm Up Catalyst; Bank 2: Efficiency Below Threshold
P0431 - 001 - Upper Limit Exceeded - MIL ON
17887 - Brake Boost Vacuum System: Mechanical Failure
P1479 - 008 - Implausible Signal - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 001 - Upper Limit Exceeded - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4B0 927 156 FF
Component: AG5 01V 3.0l5V USA 1213
Coding: 0001002
Shop #: WSC 08212 444 64365
No fault code found.
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 H
Component: ABS/ESP allrad 1728
Coding: 06497
Shop #: WSC 00000
2 Faults Found:
01425 - Yaw Rate Sensor (G202); Signal Wire
57-10 - Electric Circuit Failure - Intermittent
01119 - Gear Recognition Signal
35-10 - - - Intermittent
Address 06: Seat Mem. Pass Labels: None
Part No: 4B0 959 760 C
Component: Sitzmemory R1 BF 0102
Coding: 00003
Shop #: WSC 00000
1 Fault Found:
00668 - Supply Voltage Terminal 30
07-10 - Signal too Low - Intermittent
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 4B0 820 043 AD
Component: A6-Klimavollautomat 0105
Coding: 00110
Shop #: WSC 02325
1 Fault Found:
01592 - Air Quality Sensor (G238)
57-00 - Electric Circuit Failure
Address 15: Airbags Labels: None
Part No: 4B0 959 655 N
Component: Airbag 8.4E 3001
Coding: 0000307
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 C
Component: Lenkradelektronik D01
Coding: 01002
Shop #: WSC 02325
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 981 N
Component: KOMBI+WEGFAHRS. VDO D09
Coding: 02262
Shop #: WSC 00001
WAULT64B32N061025 AUZ7Z0A1994058
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 J
Component: Central Lock/Alarm D35
Coding: 15885
Shop #: WSC 02325
3 Faults Found:
01559 - Drivers Door
58-10 - Can't Lock - Intermittent
01561 - Left Rear Door
59-10 - Can't Unlock - Intermittent
01562 - Right Rear Door
59-00 - Can't Unlock
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0101
Coding: 00001
Shop #: WSC 00000
Address 45: Inter. Monitor Labels: None
Part No: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00101
Shop #: WSC 02325
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D06
Coding: 00050
Shop #: WSC 02325
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 4B0 035 195 J
Component: symphony II NP2 0008
Coding: 00201
Shop #: WSC 00000
5 Faults Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
44-10 - Short Circuit - Intermittent
00878 - Connection to Speaker Front Left
36-10 - Open Circuit - Intermittent
00879 - Connection to Speaker Front Right
00856 - Radio Antenna
01336 - Data Bus for Comfort System
49-10 - No Communications - Intermittent
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283
Component: Parkingsyst. A6 USA D08
Coding: 01126
Shop #: WSC 02325
1 Fault Found:
01548 - Sensor for Parking Aid; Rear Right (G206)
30-10 - Open or Short to Plus - Intermittent
End ---------------------------------------------------------------------
Anyone care to take a crack at the engine codes and the 1119 in the ABS codes. I will be ordering the repair manual this weekend. But need to get a idea where I stand on this car. Another thing that gets me going is the radio codes. I just replaced this radio with one of ECS's units, So I would assume there should be no codes for it. Last 2 scans there were NO radio codes.
On the way to work this morning, there was a vibration, almost like something was stuck rubbing on one of the front tires.Pulled overchecked things over, all was well. I continued to work and figured maybe it was a chunk of ice from the wheel well making contact with the wheel. Now on the way home I was starting to speed up a little (70 up to 75 or so). I felt a slight loss of power, and check eng. light began to flash. then went solid. So get it home and scan away, above is what I got.I did check ross-tech's wiki page of codes. But unfortunatly without the repair manual, im kinda going at it blind.
I bought this car knowing it needed some work, the price was right and I cant really complain. But without the Bently, I cant do much. Plus being a beginner with Vag-com and not knowing all its capabilitys...Well lets just say it make for a big handicap..But I am learning as I go.
James K.
76 77
VIN: WAULT64B32N
Coding: 0016752
5 Faults Found:
Coding: 0001002
Coding: 06497
Shop #: WSC 00000
2 Faults Found:
Coding: 00003
Shop #: WSC 00000
1 Fault Found:
Coding: 00110
Shop #: WSC 02325
1 Fault Found:
Coding: 0000307
Coding: 01002
Shop #: WSC 02325
Coding: 02262
Shop #: WSC 00001
Coding: 15885
Shop #: WSC 02325
3 Faults Found:
Coding: 00001
Shop #: WSC 00000
Coding: 00101
Shop #: WSC 02325
Coding: 00050
Shop #: WSC 02325
Coding: 00201
Shop #: WSC 00000
5 Faults Found:
Coding: 01126
Shop #: WSC 02325
1 Fault Found:
James K.
4Driver4
01-06-2007 07:24 PM
