Vag com Problem with TB adaption
hellow my name is marco and i have a problem with my audi a6 99 2.8 quattro
I tried to do a TBA but my vagcom 812.4 say Adaption Error i do know wath to do
if you have shareware version this can not do adaptation
http://www.ross-tech.com/vcds-lite/index.html
Some of the common differences between versions and between VCDS-Lite as Fully Registered versus Shareware:
Shareware:
Cannot do AutoScan
Won't display text for all fault codes
No Basic Settings (so no TBA, Xenon levelling, etc or checking timing on TDI's)
No Adaptation Saving (so no changing of locking/lights/horn behavior)
No Output Tests
No tech support from Ross-Tech
Limitations of VCDS-Lite compared to VCDS even if Fully Registered:
No Generic OBD-II
Won't work with CAN-Bus vehicles
Fewer fault code definitions and label files
No built-in Activation (you'll be limited to a single PC)
No Advanced Measuring Blocks
No Acceleration Measurement
Shareware:
Cannot do AutoScan
No Output Tests
No Generic OBD-II
SoCal Mike
16
07-17-2007 06:49 PM
S40RCE:Smurf
VAG-COM Discussion
05-05-2007 05:31 AM
berlina
Audi 100 / A6 (C4 Platform)
9
01-13-2006 12:02 PM
