Valve Cover recommendations please....
I know this is subject to a million different opinions but I am having my valve cover gaskets replaced (2.8L) to stop the bleeding! I always buy my own parts and just give them to my mechanic. I don't care how much the gaskets cost as long as they keep the oil off my driveway. Can you guys, that have experience with this job, give me your opinion on what brand gaskets to buy?
Thanks in advance!
Thanks in advance!
I took the car to my guy yesterday and we spoke about it for an hour or so. I mentioned the cam seals several times. Perhaps (and likely) I was not understanding what he was telling me but he pulled some old cam adjusters and showed my what fails. He said its a miserable job that included retiming the cams, etc. Obviously, he will do whatever I ask him to. I always ask him to fix whatever he would fix if it was his car. That being said, was I misunderstanding something? Are the cam seals an easy fix while you are in there? He is also changing the TB/WP.
Thanks for the great info guys. I really appreciate it since this is my first Audi.
Keep it coming!
Keep it coming!
Cam seals are different than cam adjuster seals. I wouldn't describe either as a miserable job, but I guess that's just a preference.
Cam adjuster seals fail when the half moon seal shrinks, allowing a fairly massive leak. They are a much more common failure than VCGs. In fact, many healthy VCGs are mistakenly replaced when trying to fix a cam adjuster seal leak.
All the cam related seals should be done with the timing belt service. If you do this, you should never have any upper engine leaks. How soon is your belt due?
I am buying the TB/WP as we speak. I am taking it in to have it done as soon as the parts come in. I bought the car used and would rather have the piece of mind that it's good for another 100K than have to worry and wonder if it was done. The car leaks pretty good. The last owner clearly tried to change the VCG and did a real sloppy job.
Keep it coming!
Keep it coming!
Don't do it in stages. Do it all at once.
Belt
Pump
idler
tensioner wheel
Tensioner levler
tensioner
t-stat
cam seals (4)
cam adjuster seals (2)
cam plugs (2)
VCG
What did I miss, guys?
Belt
Pump
idler
tensioner wheel
Tensioner levler
tensioner
t-stat
cam seals (4)
cam plugs (2)
VCG
Also 4driver4, do you do the crank seal? I know the Blauparts instructions caution that it's very easy to damage the toothed pulley if you remove it. I skipped the crank seal for this reason even though I had a replacement in the kit. It didn't appear to be leaking anyway.
