VERY hot engine...is this normal????
#11
i have a 2000 a4 2.8 quattro and am having a similar problem. can any one point me to where the auxillary fan control module can be found please, thanks.
#12
The control module:
- Take off the splash pan - belly pan - whatever pan
- Find the cables/wires that are connected to the fan, follow them to the module as its on the drivers side. Its a silver small box with the two cables running from it. Its an easy spot. If it failed, it's a $ 160-180 for a new one. Aux fans can be just as expensive.
#13
Buy it from here. Its a good quality place. I get parts from here. This is usually OEM parts.
http://www.autohausaz.com/search/pro...lid=1368165@A6 QUATTRO &year=2001&cid=16@Cooling System&gid=2180@Radiator Fan Controller/Resistor
#14
Sorry. Link is messed up.
Stribel/OES
Radiator Fan Controller/Resistor; Control Module for Auxillary Fan
For models with air conditioning. Please verify existing part number prior to ordering. 1 per car.
$151.25
Stribel/OES
$151.25
#15
ok so i hard wired the fan to the battery and it wouldnt work so i replaced it, before i put the new fan in i checked it by hard wiring it to the battery and it worked fine, but it still doesnt run when the engine gets hot, i have checked the cables and at no point is the fan getting power from the fan control module. i am not getting any power to the fan control module, does anyone know where the power comes from, and where is the relay that controls the fan?
a big thanks to any one that can help
forced induxion
07-03-2006 01:03 PM
gimik
04-06-2006 07:18 PM
dan-needabimma
01-20-2006 06:16 AM
