W00T! fixed my clunking steering wheel problem! loose steering rack bolt...
well i started with the basics before i jumped into the inner TRE... pulled the battery and the tray out and found one of the rack bolts FINGER LOOSE!! i could turn it by hand and it had back itself out of its hole about 3 turns... the other one was still fine. tightened the loose one and no more clunking when turning the wheel back and fourth! easiest fix ive ever made on this car =)
PSA: if you hear clunking turning the wheel at low speeds (1st gear parking lot, backing out of a parking spot, or turning the wheel while stationary) CHECK YOUR RACK BOLTS before you start replacing things like CA's, TRE's, or even the rack its self.
My rule is all fasteners get either loctite or antiseize.
There are about 40 grades/types of loctite but green, blue, or red will generally work on most fasteners. I don't even use green (the lightest), blue is medium strength, red is pretty tough.
overtorquing these little bolts is as bad as undertorquing them...too much stretches/breaks the bolt or strips the aluminum threads (have to helicoil the hole, maybe can be done in-car with enough room to move the rack). Correct torque with loctite is bulletproof.
Not being critical...good on you that you fixed it!!
s/c 6
08-08-2004 03:47 PM
