Warm-up procedure
Old 01-24-2001, 08:14 PM
  #11
Junior Member
Wade(4.2-2.4)+T's Avatar
Great! I still think Audi should pay you for your contributions here.
Old 01-24-2001, 08:25 PM
  #12
Finman's Avatar
Default I just get in and go...
by the time I get out of my driveway, neighborhood, etc. it's about 1-1/2 miles that I probably don't go above 2000rpm or 30mph.
Overall, I usually take it easily until it's a little warmed up (at least 150-160 degrees), but even when I lived in chilly NYC, I'd just turn on my CRX and take off without regard to engine speed and it easily made 165,000 miles and never burned any oil (and still runs and lives in my garage!).
Agree with Wade 4.2 and the manual, although I do question how idling affects engine wear. The amount of time wasted idling is virtually nil compared to the amount of time driving so I doubt the engine is going to die anytime sooner if it gets idled for a few minutes.
Do whatever you're comfortable with, I doubt it makes any difference as long as you're not gunning a cold engine (which, as you said, you're not).
Old 01-24-2001, 09:35 PM
  #13
Junior Member
Audiablo's Avatar
Well there ya go! Thou shalt not idle!
Old 01-25-2001, 04:47 AM
  #14
Richard Solomon's Avatar
Hmmmm, we need one in CO....
Old 01-25-2001, 05:47 AM
  #15
SLLAW's Avatar
Default Watch the oil temperature guage.
After reviewing the owner's manual for my 2001 4.2, I pay close attention to the oil temperature guage. The owner's manual says it's OK to run the engine hard once the oil temperature gets to about 175 degrees Fahrenheit, which occurs several minutes after the coolant is warm.
Old 01-25-2001, 09:31 AM
  #16
Finman's Avatar
Default 175 degrees is as high as mine ever goes
My oil temp has never exceeded the midway mark between 150-200 even after nearly an hour straight of 100+ mph. I don't drive mine hard until it starts moving above the 150 mark, but 150 to 175 takes only a minute or so of driving beyond the time it took to get to 150.
Old 01-25-2001, 09:45 AM
  #17
Junior Member
Steve's 3.2 TT/Avant's Avatar
Default Have you had the gauge checked. That almost certainly isn't working correctly.
My 98 2.8 ran around 210, and my 2.7's running right under 225 when warmed up.
Old 01-25-2001, 10:33 AM
  #18
Finman's Avatar
Default Not checked, will ask at 5k service next month, but
figured the 8 cylinder may run a bit cooler than the 210-220 that I've seen here that most 2.7Ts run. Overall, I guess I haven't been too worried, I remember one of the 4.2s I test drove peaked at about 185.
Will see, thanks.
Old 01-25-2001, 11:45 AM
  #19
Brian-PA's Avatar
same here 225 up to 250 after warm up - consistently
Old 01-25-2001, 09:03 PM
  #20
JP4
JP4's Avatar
Default Ambient temp has a big effect on what the oil temp runs and can explain some of the variance.
The oil temp on my A6 4.2 runs at around 175 when the ambient temperature is below freezing and 25 to 50 degrees warmer when ambient temps are warmer. Oil type (mineral or synth) and viscosity are also variables that have an effect on what the operating oil temp will be under a given set of conditions.
I agree with SLLA642 and the manual. I don't allow RPM to exceed 3k until the oil temp is around 175F. And I have ALSO noticed that this doesn't occur until several minutes after the coolant is up to normal operating temp (thermostat is opening to maintain coolant temp). This may be a bit conservative but I'm comfortable with it and believe it will help avoid excessive wear on a cold engine.
Quick Reply: Warm-up procedure
